Old 11-12-2014, 20:50   #1 (permalink)
Member: 1916900
Sonork: .::NIGAM::.
Thanks Meter: 81
karbonn A1 star formet error need help
karbonn A1 star formet error need help before it was hang on logo i flash with og flasher phone become dead now i try with infinity box show this error what will be the problem need help
Chinese Miracle II [MTK module] v 1.06
Operation : Format FileSystem [ v1.06 ]
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Elapsed: 00:00:41
Reconnect Power/Cable!
Wait for phone...
Phone found! [ 74 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND :
Error : DA init Failed! Error code : 0x4
Boot Error!
Elapsed: 00:00:13
Wait for phone...
Phone found! [ 74 ]
Sync...
Brom Init not done
Boot Error!
Elapsed: 00:00:01
Wait for phone...
Phone found! [ 35 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
NAND_ID : 00C800BC009000550054007F007F0000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x008E , [Acsip] A5R4GA41ATS
[NAND] : FLASH_DIE : 00C8 00BC 0090 0055 0054 007F 007F
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Error read initial info , blank flash or wrong settings?
Operation Failed
Elapsed: 00:00:09
Old 11-12-2014, 20:59   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Can you make "Flash Read" , pack and upload dump somewhere?
The Following User Says Thank You to Dzirt For This Useful Post:
Old 11-12-2014, 23:20   #3 (permalink)
Member: 1916900
Sonork: .::NIGAM::.
Thanks Meter: 81
here is readed file from phone :- MT6572__telacom72_wet_jb3
Page generated in 0.15908 seconds with 8 queries
