Old 08-31-2015, 20:24   #1 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Karbonn A19 Preloader Init Failed! Looks like HW error or incompatible image
Dear Friends,
It's Karbonn A19, Status Of Cellphone, In Dead Condition.
Got Some Information From Customer Of This Cellphone, Cellphone Had Hang At Logo Problem. Someone Software Technician Flash Or Format With Wrong Firmware Or Something Else Don't Know Exactly.
Operation : Check / Read Info [ v1.27 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164048601A36E5F517F
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A36E5F517F
[eMMC] : FLASH_LEN : 0x00000000E7000000
INT RAM    : 0x00020000
EXT RAM    : 0x20000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Info read not done :( Erased phone or unsupported FlashIc?
Done!
Elapsed: 00:00:15
Reconnect Power/Cable!
Operation : Flash [ v1.27 ]
======= Flash
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : vsun72_w_kk , Storage : EMMC
Setting : AFF verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000880000-0x0000000000100000
Erase : 0x0000000002580000-0x0000000098A40000
Flash Pre-Erase Done, time used : 00:00:22
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_vsun72_w_kk.bin
Done!
Elapsed: 00:00:48
Operation : Flash Erase [ v1.27 ]
User accepted Flash Erase operation!
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Erase Flash now ...
Erase whole flash
Flash erase done
Done!
Elapsed: 00:00:27
Wait for phone...
Phone found! [ 9 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00A8
DRAM Init Ok , 0x20000000
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:10
======= Flash
Wait for phone...
Phone found! [ 9 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Switching to HSUSB
HSUSB Init Ok
Done!
Elapsed: 00:01:09
Preloader Status : Not active (Erased) After "Flash Erase" Without "Keep Preloader".
Is It eMMC IC Problem ?. Even Reading & Writing Both Work.
Old 08-31-2015, 20:38   #2 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Found Two Threads, Who Have Problem Like Me.
http://forum.gsmhosting.com/vbb/f296...lp-me-1964603/
http://forum.gsmhosting.com/vbb/f296...error-1950820/
Old 09-01-2015, 04:49   #3 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
@mygsm world
Use SPFT & post the resur
There is many version of a19;and I m sure ubr using right one same as handset have written in back side
The Following User Says Thank You to VIJAY2U2 For This Useful Post:
Page generated in 0.18109 seconds with 8 queries
