MyGSM World | 09-04-2015 20:21 | Karbonn A20 & Singtech Z500 Both Are Same Cellphone, For More Info Check Inside Dear Friends,
Karbonn A20 & Singtech Z500 Both Are Same Cellphone, :):D:)
You Can Convert Each Other, You Can Use Factory Firmware Each Other.
Operation : Check / Read Info [ v1.28 ] Code:
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 7001004D4D43303447582A58776E714B
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0070 , OEM : 0100
[eMMC] : FLASH_INF : G40CM
[eMMC] : FLASH_CID : 7001004D4D43303447582A58776E714B
[eMMC] : FLASH_LEN : 0x00000000E6800000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : ST
ProdName : ST
ProdModel : ST
Device : ST
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.JB3.MP.V1
MODEM :
BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V1_P4_1_wg_n
EXTRA :
LCD [0] : otm8018b_dsi_vdo_fwvga_k268jiaju
LCD Res : 854x480
TOUCH [0] : ft6206
TOUCH [1] : qt602240
CAM [0] : hm2056_yuv
CAM [1] : hm5065mipi_yuv
CAM [2] : gc0329_yuv
CAM [3] : hi704_yuv
MODEM : KPHONE72_JB3_HSPA_K268_B1_GSM4_nojingti_youGPS
LOCALE : en_US my_MM km_KH hdpi
Done!
Elapsed: 00:00:19
Reconnect Power/Cable!
Operation : Read Flash [ v1.28 ] Code:
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
Brand : ST
ProdName : ST
ProdModel : ST
Device : ST
AndroidVer: 4.2.2
MTKxCPU : MT6572
[Read Ok] : preloader_kphone72_wet_jb3.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[Read Ok] : fat.img
[ScatCFG] : MT6572 / V1.1.1 / kphone72_wet_jb3 / EMMC
FW Size : 678 MiB
Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__ST__ST__ST__4.2.2__ALPS.JB3.MP.V1\
All done!
Done!
Elapsed: 00:03:28
Operation : Flash [ v1.28 ] With Karbonn A20 Firmware Code:
======= Flash
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : kphone72_wet_jb3 , Storage : EMMC
Setting : AFF verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000002300000-0x0000000097A40000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_kphone72_wet_jb3.bin
Preloader Sent , Init passed
PartCount : 0013
Update PMT by user request
Repartition Done!
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Write Error! Something went wrong!
Done!
Elapsed: 00:02:18
Operation : Repair Security [ v1.28 ] Code:
Wait for phone...
Phone found! [ 4 ]
Sync...
Init Ok, waiting for phone ...
Reading initial info, wait...
Phone Info :
BB : MT6572, E01
HW : KPHONE72_WET_JB3_HSPA_HW
SW : MOLY.WR8.W1315.MD.WG.MP.V1.P4
MM : 2000.00.00
VR : 1.0
SN : 091601MT0123459649_151454 10P
Security Info :
IMEI [1] : Damaged!
IMEI [2] : Damaged or not exists
Read Ok!
Update IMEI[1] to : 911363750XXXXXX done!
Update IMEI[2] to : 911363750XXXXXX done!
Done!
Elapsed: 00:00:59
Reconnect Power/Cable! |
