Old 01-09-2015, 17:29   #1 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Karbonn A4 Bad file detected!
I Have 2 Phones With Network Problem, & 1 Is Working Well, So Decided To Read Flash File From Working Phone For Write To Faulty Phone.
Operation : Check / Read Info [ v1.08 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
BB_CPU_NM : [MediaTek] MT6575_S00
Processing BROM stage
i2c Init : 00000000
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Stat : v3.2 on BBID : 0x84
DA Sent. Configure setting now ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0065 , [TOSHIBA] TC58NYG0S8C
[NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 0000 0000
[NAND] : FLASH_LEN : 0x20000000
INT RAM    : 0x00020000
EXT RAM    : 0x10000000
BOOT TYPE  : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Initial info read Ok!
Done!
Elapsed: 00:00:19
Reconnect Power/Cable!
Operation : Read Flash [ v1.08 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
i2c Init : 00000000
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
Read Ok , collect info
Saved to : C:\InfinityBox\CM2MTK\Flash\6575_Temp_dump.ispff
Done!
Elapsed: 00:04:26
When I Load Bin File.
Load File
Bad file detected!
When I Click On "Flash"
Operation : Flash [ v1.08 ]
======= Flash
Files set for flashing :
[ MCU ] :
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
i2c Init : 00000000
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Automatically One Window Open With "CM2MTK" Name.
Cannot Open File ''''. The System Cannot Find The Path Specified.
Old 01-09-2015, 17:41   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
It is nand, what mean - it not supported for writing yet.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 01-09-2015, 17:42   #3 (permalink)
Member: 1228709
Thanks Meter: 268
As i know, you can not write flash file in NAND-based phones
Old 01-09-2015, 17:52   #4 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
My Dear Best Friend,
Any Way To Read NV File Of This Phone ?.
Old 01-09-2015, 18:02   #5 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
NV , same as any other part for nand - lot of troubles. But will try make at least that.
Old 02-09-2015, 17:15   #6 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friends,
Karbonn A4 Have Two Version.
(1) [NAND] : FLASH_VEN : 0x0065 , [TOSHIBA] TC58NYG0S8C
(2) [NAND] : FLASH_VEN : 0x006E , [MICRON] MT29F1G16ABB
I Have Both Of Version Handset In My Hand.
1st One Handset With Full Network & IMEI Okay.
2nd One Handset With (No Service) & IMEI Okay.
So I Wanted To Read NVRAM From 1st One To Write 2nd One.
But It's Show This Error.
Operation : Write NVRAM [ v1.11 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
i2c Init : 00000000
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
DA started successuflly
[NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000
SOC VERIFY : C1
Boot Ok!
Not supported FlashType yet for this operation !!!
Done!
Elapsed: 00:00:13
Old 02-09-2015, 17:41   #7 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
As Far As I know Nand Writing Still No Supported
Chinese Miracle-2 MTK/MediaTek v1.11 released
MediaTek SP Platform
New feature supported: NVRAM Read/Write
- Read NVRAM data: MT6571-MT8392 (NAND/eMMC)
- Write NVRAM data: MT6571-MT6589, MT8312-MT8389 (eMMC only)
The Following User Says Thank You to VIJAY2U2 For This Useful Post:
Page generated in 0.22643 seconds with 9 queries
