07-07-2015, 09:56 | #1 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Karbonn A95 SC77xx_NAND Can't Read PatternLock Code: Loading : A95_W138_TJZ_062_V2.3_140819.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx_NAND PacVersion : W138_TJZ_062_V2.3_140819 FastCheck : 0x22C48AA6 Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : prodnv_b128k_p2k.img File : u-boot-spl-16k.bin File : SC7702_sc7715_modem.bin File : DSP_DM_G2.bin File : SC8800G_sc7715_wcn_modem.bin File : logo.bmp File : boot.img File : system_b128k_p2k.img File : cache_b128k_p2k.img File : recovery.img File : userdata_b128k_p2k.img File : u-boot.bin File : prodnv_b256k_p4k.img File : system_b256k_p4k.img File : cache_b256k_p4k.img File : userdata_b256k_p4k.img File : SC77xx_NAND.xml Load Ok! Operation : Check/Read Info [ v1.02 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 175 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : NAND Flash , Structure : Ok! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Read PatternLock [ v1.02 ] Code: 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 175 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : Error Done! Elapsed: 00:04:47 Reconnect Power/Cable! Operation : Format File System [ v1.02 ] Code: Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 175 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Flash [ v1.02 ] Code: ======= Flash Files set for flashing : [ MCU ] : A95_W138_TJZ_062_V2.3_140819.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx_NAND PacVersion : W138_TJZ_062_V2.3_140819 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : prodnv_b128k_p2k.img File : u-boot-spl-16k.bin File : SC7702_sc7715_modem.bin File : DSP_DM_G2.bin File : SC8800G_sc7715_wcn_modem.bin File : logo.bmp File : boot.img File : system_b128k_p2k.img File : cache_b128k_p2k.img File : recovery.img File : userdata_b128k_p2k.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 175 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x16 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv_b128k_p2k.img Flashing now ... [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_sc7715_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_sc7715_wcn_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system_b128k_p2k.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache_b128k_p2k.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata_b128k_p2k.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:01:57 Reconnect Power/Cable! Pattern Lock Removed After Format. After Flash Hang At Logo. With Factory Flash Tool Cellphone Working Fine. |
07-07-2015, 10:25 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Phone have "Dual Page" type. Not have such sample yet to make correct support. |
