Old 08-22-2016, 13:10   #1 (permalink)
andyvikas's Avatar
Member: 449069
Thanks Meter: 61
Karbonn Alfa A112 Unable to flash!!!!
Hi,
Operation : Flash
======= Settings
Settings : Factory Settings Enabled
======= Flash
Files set for flashing :
RDATotal File : R400B_Karbonn_Alfa_A112_V08_13_04_2016_0958_rda_total.bin
Load Ok : PDL1
Load Ok : PDL2
Load Ok : bootloader
Load Ok : boot
Load Ok : system
Load Ok : modem
Load Ok : customer
Load Ok : recovery
Waiting phone ...
Connect battery, press and hold 'VolUP' + 'PowerOn' buttons
Connect USB cable and keep hold buttons, until phone will be detected
Device found!
Handshake Ok!
[PDL] : Setting FlashMode ...
[PDLBoot] : Sending First PDL ...
[PDLBoot] : First Boot Ok!
[PDLBoot] : Sending Second PDL ...
[PDLBoot] : Second Boot Ok!
Boot Finished!
Handshake with FL Ok!
Factory Defaults Enabled, will reset UserData and Settings!
Format UDA partition ...
Format USER Ok
[PDLFlash] : Sending All Images
[PDLFlash] : Processing now BOOTLOADER
Flashing ...
[PDLFlash] : Flash region done!
Flashing ...
[PDLFlash] : ERROR! PartitionFinalize rejected! Check FlashFile and connection!
Flashing Done!
Reboot Phone
Elapsed: 00:00:30
Reconnect Power/Cable!
Initially set was with sofware errors(Apps unfortunately closed), now its fully dead!!!
How to solve?
Thanks
Old 08-22-2016, 14:29   #2 (permalink)
Member: 2082450
Thanks Meter: 1,454
Hello,
Problem already reported to team.
Hope, it will be solved on upcoming update ver.
Till then can use og flasher to flash and revive it...
The Following User Says Thank You to chandanps18 For This Useful Post:
Old 08-22-2016, 14:41   #3 (permalink)
andyvikas's Avatar
Member: 449069
Thanks Meter: 61
Hi,
can you share OG flasher link?
Thanks
Old 08-22-2016, 15:00   #4 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Originally Posted by andyvikas View Post
Hi,
Thanks
https://forum.gsmhosting.com/vbb/****************************/?hrjk293zcxlyfl5
Br - srinibas
Old 08-22-2016, 15:20   #5 (permalink)
andyvikas's Avatar
Member: 449069
Thanks Meter: 61
Originally Posted by srinibas View Post
Hi,
Solved problem, but above flasher isn't working.....
Used
"Multi_Update_Tools_Release_v3.0.0.2_20150323"
Thanks
The Following User Says Thank You to andyvikas For This Useful Post:
Old 12-27-2017, 16:09   #6 (permalink)
sachu2002's Avatar
Member: 2362867
Sonork: ththtuu
Thanks Meter: 659
Card found : S/N : AD4A22C5 , v0136
Chinese Miracle II [RDA module] v 1.05
Operation : Check Device / Info
======= Settings
Settings : Read AllInfo is Off
Settings : Full Boot disabled by default
Waiting phone ...
Device found!
Handshake Ok!
Processing UBOT init ...
UBOOT FCS Init Ok!
Processing FL init ...
Reading Info ...
RDA 881x series CPU
Detected 1 Sim Slot(s)
Current Phone IMEI's :
IMEI1 : 000000000000000
Connectivity Data :
BT_MAC : 000000000000
WiFi_MAC : 000000000000
Elapsed: 00:00:33
Operation : Format File System
Settings : SmartFormat is On
Waiting phone ...
Device found!
Handshake Ok!
UBOOT FCS Init Ok!
Factory Defaults : Will reset UserData and Settings!
Format USERDATA partition ...
Format USER Ok
Reboot Phone
Elapsed: 00:00:13
Load file...
RDATotal : R400B_Karbonn_Alfa_A112_V10_30_01_2016_1428_rda_to tal.bin
Load Ok
Operation : Flash
======= Settings
======= Flash
RDATotal File : R400B_Karbonn_Alfa_A112_V10_30_01_2016_1428_rda_to tal.bin
Load Ok : PDL1
Load Ok : PDL2
Load Ok : boot
Load Ok : system
Load Ok : modem
Load Ok : customer
Load Ok : recovery
Waiting phone ...
Device found!
Handshake Ok!
Boot Finished!
Format USER Ok
Flashing ...
Flashing ...
[PDLFlash] : Processing now SYSTEM
Flashing ...
[PDLFlash] : Processing now MODEM
Flashing ...
[PDLFlash] : Processing now CUSTOMER
Flashing ...
[PDLFlash] : Processing now RECOVERY
Flashing ...
Flashing Done!
Reboot Phone
Elapsed: 00:53:23
Old 12-27-2017, 16:17   #7 (permalink)
sachu2002's Avatar
Member: 2362867
Sonork: ththtuu
Thanks Meter: 659
after flash still same
Old 12-27-2017, 20:13   #8 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Since it even not send its security block, probably, there is HW reason of problem.
Page generated in 0.16112 seconds with 8 queries
