05-02-2011, 09:37 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: india Age: 43
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | karbonn k444i show fdm version missmatch thanxx |
05-02-2011, 11:33 | #3 (permalink) | |
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | Quote:
i format complete mode befor flashing but not sucess. its same condition. after full flash & make format complete modei sucess. thanxx support team flashing logs:> Code: COM15 [VCP0] selected module v3.23 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash write: Firmware Karbonn-K444i_SIMCOM23_08A_PCB01_GPRS_MT6223_S00.K444I_F10N2V01_02B01_2010-08-06_16m_En_Hi.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:5CC1:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: SIMCOM23_08A_PCB01_GPRS_MT6223_S00.K444I_F10N2V01_02B01.BIN project-id: K444i_F10N2v01.02b01, 00000000 code offset: 00000000 ffs offset/size [01]: 00D00000/00300000 rom info structure: [standard] type (04) TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 2088C4FFFF0043:2088C400000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 24 min 0 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? Code: COM15 [VCP0] selected module v3.23 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:5CC1:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: SIMCOM23_08A_PCB01_GPRS_MT6223_S00.K444I_F10N2V01_02B01.BIN project-id: K444i_F10N2v01.02b01, 00000000 code offset: 00000000 ffs offset/size [01]: 00D00000/00300000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00D00000 standard ffs/eeprom offset confirmed: 00D00000 detecting ffs/eeprom size... ffs/eeprom size: 00300000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00D00000-00FFFFFF firmware area: 00000000-00CFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088C4FFFF0043:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088C4FFFF0043:2088C400000000 Finalization Done Finished, time used: 1 min 16 sec Remove/Install battery now ! | |
The Following 2 Users Say Thank You to royal_electronics For This Useful Post: |
06-15-2011, 10:42 | #4 (permalink) |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | thanks pawan i recover dead karbonk444i here is log COM4 [VCP2] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware Karbonn-K444i_SIMCOM23_08A_PCB01_GPRS_MT6223_S00.K444I_F10 N2V01_02B01_2010-08-06_16m_En_Hi.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:8F10:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.3.26, database date: 12.02.2011): QING_S09_PCB01_GPRS_MT6223P_S00.QING-S09_INTEX_L2EN_205_090108_CAM010_MCP128+32_BT_FM.B IN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: QING_S09_PCB01_GPRS_MT6223P_S00.QING-S09_INTEX_L2EN_205_090108_CAM010_MCP128+32_BT_FM.B IN project-id: QING-S09_INTEX_L2EN_205_090108_CAM010_MCP128+32_BT_FM, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 2088C4FFFF0043:2088C400000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00D00000 Detected ffs/eeprom address is non-standard: 00D00000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00D00000 detecting ffs/eeprom size... ffs/eeprom size: 00300000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00D00000-00FFFFFF firmware area: 00000000-00CFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: QING_S09_PCB01_GPRS_MT6223P_S00.QING-S09_INTEX_L2EN_205_090108_CAM010_MCP128+32_BT_FM__ ffs... file saved: C:\Documents and Settings\jtag\My Documents\QING_S09_PCB01_GPRS_MT6223P_S00.QING-S09_INTEX_L2EN_205_090108_CAM010_MCP128+32_BT_FM__ ffs_20110615-150240.B0E.bin flash: 2088C4FFFF0043:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 2088C4FFFF0043:2088C400000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 6 min 53 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to MOHIT_THAREJA For This Useful Post: |
06-16-2011, 17:01 | #5 (permalink) |
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | karbonn k444i tested flash file many times tested this flash file .its available in support but many persion found in forum .i upload here link : > Karbonn-K444i_SIMCOM23_08A_PCB01_GPRS_MT6223_S00.K444I_F10 N2V01_02B01_2010-08-06_16m_En_Hi.B0M.bin - 4shared.com - online file sharing and storage - download |
The Following User Says Thank You to royal_electronics For This Useful Post: |
How unlock new nokia5110 version 5.20 ? | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 01-21-2011 07:45 |
5110 version 5.24 solution | lampin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-14-1999 07:00 |
New 8810 SW version | YaKuMo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-05-1999 11:22 |
How unlock Nokia version 5.20 | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-17-1999 17:35 |
