09-15-2010, 06:47 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | karbonn k447 dead need flash file module v3.17 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 350724986106673 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:AC5E:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFDFFFD:2088C400000000 flash: 2088C4FFFDFFFD:29EA0000000000 flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFDFFFD:2088C400000000 flash: 2088C4FFFDFFFD:29EA0000000000 flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFDFFFD:29EA0000000000 flash: 2088C4FFFDFFFD:29EA0000000000 flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFDFFFD:2088C400000000 flash: 2088C4FFFDFFFD:29EA0000000000 flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... slowest Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFDFFFD:2088C400000000 flash: 2088C4FFFDFFFD:29EA0000000000 flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFDFFFD:2088C400000000 flash: 2088C4FFFDFFFD:29EA0000000000 flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb otp offset: 00FE0000 it's time to stop: 2B0002EA1AF09FE51AF09FE51AF09FE51AF09FE51AF09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 2088C4FFFDFFFD:2088C400000000 flash: 2088C4FFFDFFFD:29EA0000000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088C4FFFDFFFD:29EA0000000000 flash: 2088C4FFFDFFFD:29EA0000000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... .................................................. ...... ffs/eeprom: can't detect record name location error: ffs/eeprom detection failed element #2 error: can not detect default imei value Patch required data Fail Finished, time used: 1 min 51 sec Remove/Install battery now ! |
09-17-2010, 23:10 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, This file is not exist in support area yet. It will be good if somebody can read full flash from the same good working phone and send full flash (or RapidShare: 1-CLICK Web hosting - Easy Filehosting link) backup file to [email protected] so we will be able to prepare and upload good working files in support area for all users. --- Please, do not send to us backup files from damaged phones ! We can not repair damaged files ! |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
