09-28-2010, 20:16 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. |
09-29-2010, 07:01 | #3 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: INDIA
Member: 530721 Status: Offline Thanks Meter: 157 | yes Quote:
09-29-2010, 17:46 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. power Onphone 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone must be powered On) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
10-02-2010, 15:01 | #7 (permalink) |
Member: 530721 Status: Offline Thanks Meter: 157 | sorry for my late reply i was busy with personal work but i want some more details on this i measured all pin and 4 pins r sowing value 2 to 3.5 i am confused weather tx value is more or rx i try-ed with changing pins but on result now u only can show me right pin out please do this for me thank u |
10-03-2010, 11:20 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! how many pins is in your connector? have you found pins with voltage near to 2,8volt? voltage "2" and "3,5" is not correct. measuring must be done on Powered On phone! |
10-13-2010, 14:28 | #9 (permalink) |
Member: 530721 Status: Offline Thanks Meter: 157 | sorry for my late reply yes i successfully repaired mobile i found pin out bottom of LCD i attached screen shot and picture of pin out (picture quality is poor i dint have a good camera in my hand so picture capture from mobile) thanks to infinity team for helping me |
The Following User Says Thank You to Sandeep Mobiles For This Useful Post: |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
8810 pinout?? | timitiz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-11-2012 11:10 |
Please Help, Pinout of N8810 | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 06-30-2010 15:53 |
8810 pinouts for dejan flasher !?!?!? | makona | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-03-2001 04:39 |
8850 pinouts | MDR | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 12-30-2000 01:23 |
