Old 12-04-2014, 14:07   #1 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Karbonn Sparkle V (androidone), Info read not done
Chinese Miracle II [MTK module] v 1.07
Operation : Check / Read Info [ v1.07 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582|8312_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164040502A1E0387109
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A4834473164040502A1E0387109
[eMMC] : FLASH_LEN : 0x00000000E9000000
INT RAM    : 0x00020000
EXT RAM    : 0x40000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Info read not done :( Erased phone or unsupported FlashIc?
Done!
Elapsed: 00:00:15
Reconnect Power/Cable!
Operation : Read Flash [ v1.07 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
Read error :(
Operation Failed
Elapsed: 00:00:18
The Following User Says Thank You to MyGSM World For This Useful Post:
Old 12-04-2014, 16:43   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Hello!
Can you test same phone with v1.06?
Maybe I missed something...
P.s. : according this post : http://forum.gsmhosting.com/vbb/f296...world-1888486/
Not miss. There is exist factory fw for this phone? Will be great.
Old 12-04-2014, 17:19   #3 (permalink)
Member: 1228709
Thanks Meter: 268
Hello, here is Factory Firmware for Karbonn Sparkle V
Download 015427.zip
Old 12-04-2014, 17:39   #4 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Originally Posted by Dzirt View Post
Hello!
Dear Friend,
Here Is Test Report With V1.06.
Chinese Miracle II [MTK module] v 1.06
Operation : Check / Read Info [ v1.06 ]
Wait for phone...
Phone found! [ 202 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:18
Operation : Read Flash [ v1.06 ]
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Read error :(
Operation Failed
Elapsed: 00:00:14
Old 12-04-2014, 18:13   #5 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Thanks!
Will check it's fw and find solution soon.
Old 12-04-2014, 18:37   #6 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
@JorgeVla , got the file, thanks!
Seems as fresh eMMC phone also require some tune up. From next version will be supported.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 12-22-2014, 18:00   #7 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Still Not Work With Version 1.08
Operation : Check / Read Info [ v1.08 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
Error : Correct DA sequence not found for target!
Boot Error!
Operation Failed
Elapsed: 00:00:09
Old 12-22-2014, 18:02   #8 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Because you need change exe in current CM2MTK folder to new one, not start it from rar file
Old 12-22-2014, 18:11   #9 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Yes, My Dear Best Friend,
You Are Right.
Now Here Is Log.
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
You can change settings : Settings -> Other -> NAND/eMMC init Mode
Done!
Elapsed: 00:00:38
Where Is This Settings ?
Old 12-22-2014, 18:40   #10 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
In left up corner - File Settings Other
Settings - eMMC Init - P1
Old 12-22-2014, 18:47   #11 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Still Not Read After Settings.
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:45
Old 12-22-2014, 19:07   #12 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Ok, thanks. That mean I need to find phone for check.
Old 04-02-2015, 11:40   #13 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,405
is there any progress because i have same set i working fine i only want to read its firmware because it update to lollypop
Operation : Check / Read Info [ v1.15 ]
Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 90014A4834473164040503A2E01A9189
DA started successuflly
[eMMC] : FLASH_CID : 90014A4834473164040503A2E01A9189
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:10
Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:08
Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:08
Wait for phone...
Phone found! [ 13 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
Will use Secure DA for boot target
DA Stat : v4.2 on BBID : 0xFF
Error : DA init Failed! Error code : 0x5
Boot Error!
Operation Failed
Elapsed: 00:00:28
Old 10-21-2015, 21:39   #14 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Still Not Work With New Version.
Operation : Check / Read Info [ v1.34 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
DA Ver : MTK_AllInOne_DA_v7.1533.03
eMMC_ID : 90014A4834473164040503A1015681FD
[eMMC] : FLASH_CID : 90014A4834473164040503A1015681FD
[eMMC] : FLASH_EXT : 00400000/00400000
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:10
Old 10-22-2015, 04:29   #15 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 440
micromax A1 also have same problem jaydi need such phone for test.
Page generated in 0.24777 seconds with 8 queries
