Old 03-07-2009, 09:27   #1 (permalink)
Member: 421487
Thanks Meter: 58
ke790 unlocking problem
sir ji i attached log file of ke 790 when unlock pl give me idea where is i wrong
module v1.60
Device: LG-KE970
Checking data, wait...
Action: unlock
direct unlock
Boot ...
loading...
next part...
boot answer: 00
error: unknown bootcode answer:
Release Power button now
Boot Failed
Finished, time used: 9 sec
Remove/Install batte
Old 03-07-2009, 09:39   #2 (permalink)
mobile_hotman's Avatar
Member: 214340
Thanks Meter: 906
module v1.60
Device: LG-KE970
Action: unlock
direct unlock
Boot ...
loading...
next part...
boot answer: 00
Boot Failed
Bro I think connection problem nothing else see my logs
UNLOCKED_SUCCESSFULLY
COM11 [VCP0] selected
module v1.58
Device: LG-KE970
Action: unlock
direct unlock
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0089:88B0
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static_20081220-134355.B1E.bin
reading eeprom-static2...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static2_20081220-134355.B1E.bin
loading data...
data loaded
imei: 35030526000000100
reading eeprom-security_35030526000000100...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-security_35030526000000100_20081220-134356.B1E.bin
reading eeprom-complete_35030526000000100...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-complete_35030526000000100_20081220-134356.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
Erasing: eeprom-complete
Writing: eeprom-complete
Verifying...
Verify result: 0114
Done
probably you need to restore original imei after unlock process
Write Done
Finished, time used: 26 sec
Remove/Install battery now !
The Following User Says Thank You to mobile_hotman For This Useful Post:
Old 03-08-2009, 22:21   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
module v1.60
Device: LG-KE970
Action: unlock
direct unlock
Boot ...
loading...
next part...
boot answer: 00
Boot Failed
Hello,
Please, double check your cable.
Also you can try to use this software: http://www.infinity-box.com/download...na01_v1.64.rar
Samsung Jet S800 Unlock problem javakiller Z3X-Team Products 8 05-15-2010 12:14
Alcatel ot 103 Unlock probleme abote didier Infinity-Box 4 04-26-2010 17:04
Lg ke790 big problem GNS_KUMAR73 Infinity-Box 5 12-22-2008 16:27
Lg Ke790 Unlock?? Stylo_GSM VygisToolbox 10 12-24-2007 15:59
w200 unlock problem i think exe problem please lead look here saily Cruiser Suite 22 08-15-2007 14:31
Page generated in 0.14876 seconds with 10 queries
