Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2004 Location: morocco
Member: 85019 Status: Offline Sonork: 100.1603419 Thanks: 3
| ke820 dead hello i try to flash ke820 for change language and now phone become dead i try all flashfiles in suport and send eprom too and no result hang sometimes in white screen and powe off quily no eror during flash procedure i test too this one KE820P40-07-V10w-000-00_FEB-07-2007_file_system[1].B1S.bin w8 answer from suport |
| | #2 (permalink) |
| here log file COM8 [VCP0] selected Device: LG-KE820 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 02 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0089:887E Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-sta_20081009-112554.B1E.bin reading [eeprom-sta2]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-sta2_20081009-112557.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-sec_35030526000000100_20081009-112600.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-complete_35030526000000100_20081009-112601.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Writing: Firmware Verifying... Done Writing: FFS-2/File system Verifying... Done Writing: Eeprom Verifying... Done Write Done Finished, Remove/Install battery now ! Time used: 1005 sec |
| | #3 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2006 Location: Cirebon - Indonesia
Member: 355635 Status: Offline Thanks: 311
| Quote:
regards notgood | |
| | #5 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 9,039
| @KingOfGsm Please, check phone battery voltage, battery may be empty after flash process. Is it the same situation with all files from support (power-on with white screen) or situation is different with different flash files ? |
| | #10 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2006 Location: agadir oufla.
Member: 273511 Status: Online Thanks: 283
| i have the same issue with 2 lg ke820 : after flash tottaly dead or with blinking logo screen. hve tried all flash & eeprom repair files in support ,no way. i think i they are version m. i see the every time backup is with emei like this 35030526000000100. i maked a fuul flash backup but i tray to restor it soft said error data. so please infinitysupport can u tell what to do next. here is a log COM9 [VCP0] selected module v1.63 Device: LG-KE820 Checking data, wait... Action: read eeprom Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 02 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0089:887E Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-static_20090302-152225.B1E.bin reading eeprom-static2... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-static2_20090302-152226.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-security_35030526000000100_20090302-152228.B1E.bin reading eeprom-complete_35030526000000100... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-complete_35030526000000100_20090302-152229.B1E.bin backup critical area Done Check memory ... completed Finished, time used: 17 sec Remove/Install battery now ! OM9 [VCP0] selected module v1.63 Device: LG-KE820 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 02 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0089:887E Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-static_20090302-175450.B1E.bin reading eeprom-static2... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-static2_20090302-175451.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-security_35030526000000100_20090302-175451.B1E.bin reading eeprom-complete_35030526000000100... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE820_eeprom-complete_35030526000000100_20090302-175452.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Writing: Firmware Verifying... Done Writing: FFS-2/File system Verifying... Done Write Done Finished, time used: 1017 sec Remove/Install battery now ! Last edited by jeanbrume; 03-03-2009 at 21:08. |
| | #11 (permalink) |
| Hello, Open phone Remove (desolder) small backup battery Wait 15 min Solder battery back |
| The Following User Says Thank You to InfinitySupport For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Genie dead no power on... [ANSWERED] | lchico | Genie Universal | 1 | 03-29-2010 07:18 |
| help!! ke820 dead after flash | biri26 | FuriouS TeaM Products | 6 | 09-25-2009 23:10 |
| Vygis need your help please KE820 TOTALY dead ! | jr90 | VygisToolbox | 1 | 11-24-2008 09:26 |
| ke820 dead | KingOfGsm | VygisToolbox | 0 | 10-08-2008 21:35 |
| Ke820 File Wanted | RRRRR | LG | 0 | 02-23-2007 07:54 |
