06-17-2008, 07:34 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @djoud My congratulations ! Your post counter increased well ! Next time I suggest you DO NOT LIE and think before write something. Also you must write your "not smart" messages in correct forum due to here is Infinity-Box support forum but not "discussion about everything" KE970 completely supported by Infinity-Box. |
12-19-2008, 16:18 | #7 (permalink) |
Major Poster Join Date: Jul 2005 Age: 50
Member: 163036 Status: Offline Thanks Meter: 2 | KE970 Death I have KE970 first the fone was flashed by HWK after the flash will death of course now when i want to flash on infinity i have this info COM4 [VCP0] selected module v1.58 Device: LG-KE970 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... error: can't run main loader: Finished, time used: 7 sec Remove/Install battery now ! What i have to do ????? HELP |
12-19-2008, 16:26 | #8 (permalink) |
12-19-2008, 17:40 | #9 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | INFINITY is the best ever BOX bro i repaired now my LG_KE_970 IMEI successfully....here is the logs BEFORE Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Read info... software version: KE970P40-ARB-V10f-XXX-XX JUN 07 2007+0 imei: 35612901183211700 AFTER Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Action: imei software version: KE970P40-ARB-V10f-XXX-XX JUN 07 2007+0 original imei: 35612901183211700 new imei: 35612902345211 imei verification Ok Done Finished |
The Following User Says Thank You to mobile_hotman For This Useful Post: |
12-19-2008, 20:13 | #10 (permalink) | |
Is it was any errors during flashing with HWK ? What was phone state before flash ? | |
12-20-2008, 14:59 | #11 (permalink) |
Member: 214340 Status: Offline Thanks Meter: 906 | Now I unlocked 2 more LG_KE_970 successfully Thax again INFINITY_LOVELY_BOX i love INFINITY,, C the logs ; SET # 1 Unlocked_SUccessfull COM11 [VCP0] selected module v1.58 Device: LG-KE970 Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0089:88B0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static_20081220-134355.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static2_20081220-134355.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-security_35030526000000100_20081220-134356.B1E.bin reading eeprom-complete_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-complete_35030526000000100_20081220-134356.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 0114 Done probably you need to restore original imei after unlock process Write Done Finished, time used: 26 sec Remove/Install battery now ! ------------------------------------------------------------- SET # 2 UNLOCKED_SUCCESSFULL COM11 [VCP0] selected module v1.58 Device: LG-KE970 Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0089:88B0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static_20081220-184107.B1E.bin reading eeprom-static2... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static2_20081220-184107.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-security_35030526000000100_20081220-184108.B1E.bin reading eeprom-complete_35030526000000100... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-complete_35030526000000100_20081220-184109.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 010C Done probably you need to restore original imei after unlock process Write Done Finished, time used: 41 sec Remove/Install battery now ! |
12-21-2008, 09:16 | #13 (permalink) | |
Member: 163036 Status: Offline Thanks Meter: 2 | Quote:
but after the flash i can't swith on them. Then i try flash on Infinity Box. Is the any tp solution to boot my LG KE970 Best regards to INFINITY Support | |
ke970 hang to ke970 100000% ok ok | anam120 | LG | 6 | 08-10-2009 13:31 |
Death 3210 (v???) | iboboy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-25-2002 20:56 |
3310 v4.02 death | nomestrano | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-30-2001 09:02 |
