01-07-2016, 07:29 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | kenxinda k524 read ff error first format done Code: Operation : Format File System [ v1.11 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 70 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! Code: Operation : Read FullFlash [ v1.11 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 70 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected NAND Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Initialize Ok , 0x13 , NAND : b128k [FW_READER] : Step #3 Passed! [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv_b128k.img [Read Ok] : nvitem.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : sc7715_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : CP2._CP2_WCN_14C_W14.39_Release.bin [Read Ok] : logo_320x480.bin [Read Ok] : boot.img ReadErr : MajorErr , 0x3000:0x0000:0x14F10000 ReadErr : MajorErr , 0x2000:0x0000:0x14F10000 ReadErr : MajorErr , 0x1000:0x0000:0x14F11000 ReadErr : FatalErr , 0x1000:0x0000:0x14F11000 [Read Failed] : DataRead failed : Connection fault! [READ_ERROR] : Connection/Battery or some unknown problem! Reconnect Power/Cable! Operation : Read FullFlash [ v1.11 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 70 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected NAND Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Initialize Ok , 0x13 , NAND : b128k [FW_READER] : Step #3 Passed! [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv_b128k.img [Read Ok] : nvitem.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : sc7715_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : CP2._CP2_WCN_14C_W14.39_Release.bin [Read Ok] : logo_320x480.bin [Read Ok] : boot.img ReadErr : MajorErr , 0x3000:0x0000:0x14F10000 ReadErr : MajorErr , 0x2000:0x0000:0x14F10000 ReadErr : MajorErr , 0x1000:0x0000:0x14F11000 ReadErr : FatalErr , 0x1000:0x0000:0x14F11000 [Read Failed] : DataRead failed : Connection fault! [READ_ERROR] : Connection/Battery or some unknown problem! Reconnect Power/Cable! |
01-07-2016, 07:33 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Thanks for info. It second 128k phone. Will seek for sample to check all need things. |
