12-23-2008, 12:48 | #1 (permalink) |
Banned Join Date: Mar 2006 Location: INDIA.PANJAB.
Member: 249946 Status: Offline Sonork: 1589065 Thanks Meter: 22 | kf 600 cant be unlocked by both method plz help at lat it says n9ot locked or unknown eprom i haw write the eprom from the site but stii same pls help |
12-24-2008, 06:47 | #3 (permalink) |
Member: 249946 Status: Offline Sonork: 1589065 Thanks Meter: 22 | module v1.58 Device: LG-KF600 Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0000:0000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KF600_eeprom-static_20081224-111611.B1E.bin loading data... data loaded imei: 35200902295737200 backup critical area Done Check memory ... loading data... error: source buffer too small: 00000011 instead of 000035AE error: operation terminated [00FF] loading data... error: source buffer too small: 00000011 instead of 000035AE error: operation terminated [00FF] loading data... error: source buffer too small: 00000011 instead of 000035AE error: operation terminated [00FF] loading data... data loaded code: 11019786 code: 0000000000000000 error: not locked or unknown eeprom Check memory Failed Finished, time used: 22 sec Remove/Install battery now ! |
12-24-2008, 08:09 | #5 (permalink) |
Freak Poster Join Date: Jan 2005 Location: india
Member: 102598 Status: Offline Thanks Meter: 68 | kf600 unlock sucessfull kf600 unlock sucessfull COM12 [VCP0] selected Device: LG-KF600 Checking data, wait... Action: unlock direct unlock Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0000:0000 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KF600_eeprom-sta_20081224-123018.B1E.bin loading data... data loaded imei: 3520090xxxxxxxx backup critical area Done Check memory... loading data... data loaded loading data... data loaded loading data... data loaded loading data... data loaded code: 11019786 code: 0000000000000000 Check memory Done Write... Writing: eeprom-sta Verifying... Done Write Done Finished, Remove/Install battery now ! Time used: 29 sec |
The Following User Says Thank You to mehta For This Useful Post: |
nokia 6124c-1 rm-422 by vodafone cant be unlocked by mxkey (ANSWERED) | med26 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 07-17-2011 21:37 |
X650 Cant Be Unlock By Hwk Why? | denard | HWK | 3 | 10-10-2009 05:14 |
LG KF600 cant be unlock by both method | Maiwand khan | Infinity-Box | 1 | 10-18-2008 09:29 |
sams e250 cannot be unlocked by any method | codec_romania | NSPRO | 0 | 03-29-2007 14:29 |
V220 cant be unlocked by v2.09? | a4tech | Smart-Clip | 9 | 04-12-2005 17:30 |
