10-26-2009, 18:22 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Caribbean
Member: 237911 Status: Offline Thanks Meter: 632 | Kf600 error unlocking Code: COM6 [VCP5] selected module v1.68 Device: LG-KF600 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! s-gold3: D4 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... slowest Set Baud Done Connecting ... flash: 0000:0000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory ... Check memory Done Write ... error: set erase range error: erase is not confirmed Write Failed Finished, time used: 56 sec Remove/Install battery now ! and by the way im using UST PRO as my interface coz i dont have time of modifying my cables on infinity, but i will try while i am waiting for the answer |
10-27-2009, 17:23 | #2 (permalink) |
Member: 237911 Status: Offline Thanks Meter: 632 | now im using infinity as interface Code: COM35 [VCP3] selected module v1.68 Device: LG-KF600 Checking data, wait... Action: unlock direct unlock Boot ... Press and HOLD Power button now ! s-gold3: D4 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... slowest Set Baud Done Connecting ... flash: 0000:0000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory ... loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated [00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated [00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated [00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: can't read codes error: not locked or unknown eeprom Check memory Failed Finished, time used: 36 sec Remove/Install battery now ! same with unlocking, using direct unlock and read unlock codes. i think the infinity team dont know the answer? ill have to figure it out on my own, i guess. so goodluck to me |
10-27-2009, 17:26 | #3 (permalink) |
Member: 237911 Status: Offline Thanks Meter: 632 | i figure it out http://forum.gsmhosting.com/vbb/show...6&postcount=41 anyone here who has this file pls upload it to non rapid link? regards Last edited by eyestrain; 10-27-2009 at 17:32. |
11-01-2009, 19:43 | #7 (permalink) |
Member: 237911 Status: Offline Thanks Meter: 632 | what error did you encounter? i try to use RPS but i encounter a lot of failure, just put a full charge battery or at least 70% charge and try to flash again |
01-04-2010, 14:48 | #13 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Beograd
Member: 388046 Status: Offline Thanks Meter: 21 | For me - not work. Cable is OK Interface is Infinity Phone is locked to Orange INFO: Code: Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Read info... software version: KF600AT-01-V10b-232-005-OCT-06-2008+0 imei: 3520XXXXXXXXXXXXX Done Finished KF600 PANA01 V1.50 LOG: Code: Device: LG-KF600 Checking data, wait... Action: unlock direct unlock Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... slowest Set Baud Done Connecting... flash: 0000:0000 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory... loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated[00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated[00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated[00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: not locked or unknown eeprom Check memory Failed Finished, Remove/Install battery now ! Time used: 40 sec KF600 PANA01 V1.73 LOG: Code: module v1.73 Device: LG-KF600 Checking data, wait... Action: "sp-unlock" direct unlock Boot ... Press and HOLD Power button now ! s-gold3: D4 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... slowest Set Baud Done Connecting ... flash: 0000:0000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory ... loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated [00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated [00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: operation terminated [00FF] loading data... error: source buffer too small: 00000000 instead of 000035AE error: can't read codes error: not locked or unknown eeprom Check memory Failed Finished, time used: 37 sec Remove/Install battery now ! |
kf600 error | ENG. ADETUNJI | FuriousGold | 8 | 12-07-2009 17:46 |
kf600 error | VELIKI | VygisToolbox | 1 | 10-19-2009 22:11 |
Kf600 Successfull Unlock | bebiloku | Infinity-Box | 30 | 09-27-2008 16:14 |
