Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2007 Location: in your heart
Member: 566122 Status: Offline Thanks: 11
| KG-110 dead after flash Dear supporter ineed to change imei of kg-110 and for this purpose i made a post to you and in the reply , i got instruction for flashing. I download necessary code and flashed it ,result phone is completly dead. Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" active "keep calibration" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200 1912200000000flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current otp imei: 35269108331355 file saved: C:\Program Files\InfinityBox\LGA\eeprom__LG-KG110_20090113-194427.B1E.bin ................................ Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) flash: 01227E22212200 1912200000000Write: Alchemy data flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 1009 sec Remove/Install battery now ! anybody can guide me how to alivi it ? |
| | #3 (permalink) |
| Sir just want to change IMEI no only but let me clear imei was not in ????? form was in perfect digits but due to some problem customer want to change imei of another 15 digits. |
| | #4 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 9,039
| @tarana3263635 if you have nothing good to say it's better to be silent. your offtopic message was deleted. @aminnovelty Check phone battery voltage, charge battery. Phone can not be dead after full flash operation. |
| | #5 (permalink) |
| Respected sir still on same position infact i have wash it properly but result is still dead. Sir can i write this phoine again with some other BIN + ALCHEMY DATA file? |
| | #7 (permalink) |
| Hello, You can try to use other code/alchemy files and eeprom files. Also I suggest you to check phone hardware. Do not forget to check battery voltage. |
| | #8 (permalink) | |
| Quote:
module v1.36 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200 1912200000000flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current otp imei: 35269108331355 file saved: C:\Program Files\InfinityBox\LGA\eeprom__LG-KG110_20090116-101352.B1E.bin ........ version: 404-XXV10g91KG110P40FL Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) flash: 01227E22212200 1912200000000flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 1330 sec Remove/Install battery now ! I just FULL FLASH the phone according to given instruction HOW TO FULL FLASH , and my phone is quite ready besides i would like to note u that its IMEI has also changed as you can see into log. Thanks a lot again. | |
| The Following User Says Thank You to aminnovelty For This Useful Post: |
| | #9 (permalink) |
| Hello, I am very glad to hear about good results. Also very glad to hear that manual reading gives you an information how to flash phone correctly. |
| | #10 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2008 Location: Sri Lanka Age: 23
Member: 763865 Status: Offline Sonork: Cvlvertcharges Thanks: 249
| try thees method Full flash & SP Unlock 100000000000000000000000% working +94755327898 a_wafaz@yahoo.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| kg 220 dead after flash.... | pacisjr2 | Infinity-Box | 8 | 12-26-2008 14:59 |
| kg 275 dead after flash unlock | ras | FuriouS TeaM Products | 6 | 11-26-2007 14:52 |
| kg 800 dead after flash | ahmertelecom | FuriouS TeaM Products | 4 | 09-28-2007 22:30 |
| lg kg 110 dead after falsh | chiragp | Multi-Box | 3 | 05-02-2007 12:47 |
| KG 110 Dead (Water damage) | amol_sm | LG | 4 | 04-16-2007 00:38 |
