Old 09-12-2007, 05:02   #1 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
kg 110 strange...infinite team..pls replay
sir last 3 days i unlocked all 10 sets of KG 110 ,but today all sets came back with restart problem. then i flashed all model in all version one by one,then eeprom to all what ever available in support site ...but still problem persist.
i have gone all threads of restart problem of kg 110 but no solid solution i found out . now pls tell me what should i do now? . Even i have flashed the back up data still phones are restarting . Now pls give any solution...other wise costemers of 10 sets will not ................. u can undertand ..infinite the intilligent team.
Old 09-12-2007, 06:13   #2 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
Me Too Want The Solution For This Problem.
Pls Infinity Team Help Us..
Old 09-12-2007, 08:05   #3 (permalink)
Member: 263005
Thanks Meter: 147
Arrow
yes sir realy a lot of handsets(13pcs) restart complaint in my hand i am scared tell me pls my great INFINITY TEAM any solution for this virus
Old 09-13-2007, 04:48   #4 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
infinite team no reaply from any suppoter...pathetic....hope ...u can undrstand our cerumstancess
Old 09-14-2007, 17:32   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Dear Friends,
Once again I want to ask you: EXPLAIN THE PROBLEM SO DETAILED AS POSSIBLE !!!
It's not possible to solve the problem if problem description looks like "ohh... not work" or "ohh... I tried everything...and not work" or "ohh... I even tried nothing and again not work".
If you really have problem explain the problem, explain what you tried to do, what files was used. And before all this ALWAYS USE LATEST Infinity-Box updates from support area.
Old 09-18-2007, 14:49   #6 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
Originally Posted by InfinitySupport View Post
Dear Friends,
sir i unlocked kg110 ..10no sets ..after 2days all sets back with compian withoutsim and withsim phone restarts, then i gone all topic of restart of kg 110 in hosting but no solution i found,then i flashed all version in infinite support and write all eeprom part too. but still all sets has same problem of restart
Old 09-18-2007, 16:19   #7 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what version of LGA module are you using?
Old 09-25-2007, 16:22   #8 (permalink)
GsmExpertz.Clt's Avatar
Member: 74036
Sonork: 100.1601291
Thanks Meter: 42
i have two sets ,the saim problems, eny hope to repair my dear infinity
Old 09-25-2007, 16:31   #9 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,177
same to me but i flash the fone this version my fone is ok {KG110P40FL-91-V10g-404-XX_NOV-17-2006_Code[1].B1M}{KG110P40FL-91-V10g-404-XX_NOV-17-2006_Alchemy[1].B1P}{KG110_repair_eeprom_calibration_0E_91[1].B1E}
Old 09-27-2007, 16:11   #10 (permalink)
Member: 281925
Sonork: 100.113915
Thanks Meter: 63
today i flash my old dead set by infinity box use this trick but again restarting pro
today i flash my old dead set by infinity box use this trick but again i see restarting problem
i used latest version of lg module
golden tips= when off display light my kg110 phone & i think all phone restart but when i press any switch & not do to display light off phone run perfact
Old 03-04-2008, 18:20   #11 (permalink)
nomangsm's Avatar
Member: 121662
Thanks Meter: 39
Mate! 1st connect your phone then Flash your phone following file
1- KG110P40-20-V10b_602-03_MAY-31-2007_code
2- KG110P40-20-V10b_602-03_MAY-31-2007_alchemy_Arabic
Then only go to Service option connect your phone again then press Reset settings option your phone live.
ub team pls. replay akhil_bbsr Universalbox 3 09-04-2007 08:28
lg kg 110 unlock-to infinity team sudeeshveekey Infinity-Box 13 05-30-2007 06:03
c139 no network any help from infinit-team???? Yache Infinity-Box 5 01-25-2007 20:13
Kg 110 Manish Das Infinity-Box 3 11-28-2006 07:37
Page generated in 0.19972 seconds with 10 queries
