03-28-2009, 04:36 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: pakistan
Member: 334999 Status: Offline Thanks Meter: 225 | Kg 110 imei is "00100840000000800" plz help i try this full flash with this file but problem not solve imei write done with infinity but when phone turn on then apply code but imei still on 00100840000000800 plz help urgent thanks |
03-28-2009, 04:54 | #2 (permalink) |
Registered User Join Date: Apr 2008
Member: 742767 Status: Offline Sonork: [email protected]. Thanks Meter: 5 | write the imei in vgess box 10000000000% solution |
03-28-2009, 04:59 | #3 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Back to GSM from AV
Member: 325999 Status: Offline Thanks Meter: 113 | Quote:
REGARDS | |
03-28-2009, 05:33 | #5 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
Bro flash this file n u have 100% revived fone KG110P40FL-91-V10c-404-XX OCT 11 2006 tested by me. n then write or change IMEI n u have ok set BR | |
03-28-2009, 05:47 | #6 (permalink) |
No Life Poster Join Date: Nov 2007 Location: quantum mss
Member: 638396 Status: Offline Sonork: 100.1615405 Thanks Meter: 170 | use this firmware Bro..., KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453.B1M download at support area..., TESTED 100%....., |
03-29-2009, 10:21 | #7 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453.B1M i test too and 100%ok.thx-infinity team. |
The Following User Says Thank You to sirnavid2010 For This Useful Post: |
kg 110 imei problem 1000% solved | roshantelecom&s | Infinity-Box | 10 | 10-12-2010 22:40 |
7210c Imei is 12345610654321?plz help | kmi2 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 08-28-2010 09:52 |
lg kg 110 imei repair | bilal_mobile | Infinity-Box | 5 | 10-23-2008 15:45 |
KG-110 imei problem | Kashif Khan | Multi-Box | 2 | 06-06-2007 10:09 |
kg-110 imei ?2002000 | moie70 | Multi-Box | 0 | 06-05-2007 14:57 |
