08-10-2007, 08:26 | #1 (permalink) |
Registered User Join Date: Mar 2007 Location: jodhpur Age: 51
Member: 468435 Status: Offline Thanks Meter: 14 | Kg 110 Lg Only Whyt Light ==== log opened: [8/10/2007 11:39:34 AM] ==== Application: C:\Program Files\InfinityBox\LGA\LgA.exe Loading data, wait... [Infinity Box] v1.19 S/N: 0882:010A Wait... Current device: LG KG110 Done COM5 ready Loading file v.02... KG110P40-07-V10d-XXX-XX_AUG-24-2006_Code[1].B1M.bin loaded Loading file v.02... KG110P40-07-V10d-XXX-XX_AUG-24-2006_Alchemy[1].B1P.bin loaded Testing COM5 at 115200... COM5 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 |
08-11-2007, 05:01 | #5 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 39
Member: 170684 Status: Offline Thanks Meter: 19 | 1 flash the phone with gsmulti_v2.0 set will ok, 2 Rebuild IMEI with Furious dongel for CALL DROP. its tested 100000% working INFINITY WE ARE WAITING FOR KG 110 GOOD SOFTWARE&ALSO IMEI REBUILD OPTION FOR THAT, WE HOPE YOU WILL DO THIS. thank you |
08-11-2007, 07:08 | #6 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Calicut Kerala India Age: 46
Member: 74036 Status: Offline Sonork: 100.1601291 Thanks Meter: 42 | dear infinity, i am allso face this problem, i have three lg kg 110, please upgrade this problem as soon as posible best regards |
KG 110 LG not flashing | alunecosu_hd | Infinity-Box | 2 | 10-22-2007 12:01 |
lg kg 110 unlock-to infinity team | sudeeshveekey | Infinity-Box | 13 | 05-30-2007 06:03 |
lg kg 110 | .::PATEL TELECOM::. | LG | 7 | 03-22-2007 15:59 |
lg kg 110 | sadgsm2 | LG | 3 | 01-15-2007 17:34 |
unlocker of lg kg 110 | andy_ind | LG | 1 | 12-02-2006 11:41 |
