Old 12-08-2009, 13:57   #1 (permalink)
biochemistali's Avatar
Member: 190344
Thanks Meter: 267
Kg 130....sim card registration failed after full flash
dear infinity team.
problem. sim card registration failed after full flash.
imei number not blocked by the PTA pakistan
when press *#06# imei shown 05000 only
imei change show no afftect on 05000
this set was hanged on logo. here is the log
i need help in this issue
==== log: [12/8/2009 4:55:05 PM] ====
COM4 [VCP0] selected
module v1.39
Device: LG-KG130
Checking data, wait...
Action: flash write
Write: Firmware (code)
Skip: File system
Write: Alchemy data
Skip: Eeprom
error: no data for Alchemy data
Testing COM4 at 921600...
==== log: [12/8/2009 4:55:27 PM] ====
module v1.39
Device: LG-KG130
Action: flash write
Skip: File system
Skip: Alchemy data
Skip: Eeprom
"smart write" active
"keep calibration" active
Boot ...
Connecting, wait...
Release Power button now !
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 355311016181184
current otp imei: 355311010566661
file saved: C:\Documents and Settings\taha mobiles\Desktop\eeprom_355311016181184_LG-KG130_20091208-165551.B1E.bin
version: 234-30V10a44KG130P40FL
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
calibration area skipped
flash: 01227E22212200:00000100000000
write: 2nd chip area
Write Done
Finished, time used: 106 sec
Remove/Install battery now !
==== log: [12/8/2009 4:57:33 PM] ====
module v1.39
Device: LG-KG130
Action: unlock
unlock method: standard
Boot ...
Connecting, wait...
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
file saved: C:\Program Files\InfinityBox\LGA\eeprom_355311016181184_LG-KG130_20091208-165814.B1E.bin
Check flash Done
Check space ...
finalization done
Check space Done
Erase ...
Erase Done
Write ...
write: lock area-1
Write Done
Finished, time used: 58 sec
==== log opened: [12/8/2009 5:03:41 PM] ====
Application: C:\Program Files\InfinityBox\LGA\LgA.exe
Loading data, wait...
[Infinity Box] v1.39
S/N: 66F0:0112
Wait...
Device: LG-KG130
Done
==== log: [12/8/2009 5:04:21 PM] ====
module v1.39
Device: LG-KG130
Action: imei repair
Boot ...
Connecting, wait...
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
file saved: C:\Documents and Settings\taha mobiles\Desktop\eeprom_355311016181184_LG-KG130_20091208-170459.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 33 sec
==== log opened: [12/8/2009 5:08:39 PM] ====
S/N: 66F0:0112
Wait...
Device: LG-KG130
Done
Loading file v.02...
KG130_repair_eeprom_calibration_01.B1E.bin loaded
==== log: [12/8/2009 5:09:34 PM] ====
module v1.39
Device: LG-KG130
Action: flash write
Skip: Firmware (code)
Skip: File system
Skip: Alchemy data
Write: Eeprom
Boot ...
error: unexpected answer during boot procedure
Boot Fail
Finished, time used: 32 sec
==== log: [12/8/2009 5:10:39 PM] ====
module v1.39
Device: LG-KG130
Action: flash write
Skip: File system
Skip: Alchemy data
Write: Eeprom
Boot ...
Connecting, wait...
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 355311010566661
file saved: C:\Documents and Settings\taha mobiles\Desktop\eeprom_355311010566661_LG-KG130_20091208-171103.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write: Eeprom
Write Done
Finished, time used: 34 sec
WARNING ! Settings will be cleared, user data erased !
Make eeprom backup before this operation !
Continue ?
==== log: [12/8/2009 5:11:28 PM] ====
module v1.39
Device: LG-KG130
Action: reset
Boot ...
Connecting, wait...
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 355311010139873
file saved: C:\Documents and Settings\taha mobiles\Desktop\eeprom_355311010139873_LG-KG130_20091208-171157.B1E.bin
reading 234-30V10a44KG130P40FL_eeprom-ffs_355311010139873...
file saved: C:\Documents and Settings\taha mobiles\Desktop\234-30V10a44KG130P40FL_eeprom-ffs_355311010139873_LG-KG130_20091208-171305.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 110 sec
==== log opened: [12/8/2009 5:15:48 PM] ====
S/N: 66F0:0112
Wait...
Device: LG-KG130
Done
KG130_repair_eeprom_calibration_07.B1E.bin loaded
==== log: [12/8/2009 5:16:18 PM] ====
module v1.39
Device: LG-KG130
Action: flash write
Skip: File system
Skip: Alchemy data
Write: Eeprom
Boot ...
Boot Fail
Finished, time used: 12 sec
==== log: [12/8/2009 5:16:57 PM] ====
module v1.39
Device: LG-KG130
Action: flash write
Skip: File system
Skip: Alchemy data
Write: Eeprom
Boot ...
Connecting, wait...
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
file saved: C:\Documents and Settings\taha mobiles\Desktop\eeprom_355311010139873_LG-KG130_20091208-171721.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write: Eeprom
Write Done
Finished, time used: 36 sec
eeprom_355311016181184_LG-KG130_20091208-165551.B1E.bin loaded
==== log: [12/8/2009 5:19:34 PM] ====
module v1.39
Device: LG-KG130
Action: flash write
Skip: File system
Skip: Alchemy data
Write: Eeprom
Boot ...
Connecting, wait...
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
file saved: C:\Documents and Settings\taha mobiles\Desktop\eeprom_355311016181184_LG-KG130_20091208-171957.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write: Eeprom
Write Done
Old 12-08-2009, 18:18   #2 (permalink)
ak72342's Avatar
Member: 823250
Sonork: 100.1587800
Thanks Meter: 187
bro try to flash with other flash file.........and write good eprom............other wise change imei..................
ak
Old 12-08-2009, 18:36   #3 (permalink)
mobile_hotman's Avatar
Member: 214340
Thanks Meter: 899
@ [QUOTE=biochemistali;5118853]dear infinity team.
SIM_CARD_REGISTRATION_FAILED_MEANS 100 % LOST_STOLEN mobile,,,just for education make IMEI change n then see it will work 100%,,
Old 12-09-2009, 02:55   #4 (permalink)
Member: 190344
Thanks Meter: 267
no.this is not the case here. as i have checked on pta sie, the imei of phone is not blocked . so far i have diagnosed the fault is the its imei number 08000 only after full flash and it does not lter with imei change options when we write a new imei on it.
Old 12-09-2009, 03:15   #5 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 324
Restore IMEI it will be ok.OTP and EEprom imei are different.Otp IMEI is original one write it.
Old 12-09-2009, 04:39   #6 (permalink)
Member: 190344
Thanks Meter: 267
even when i restore the the original imei , the imei number remains 05000 only when i check by *#06#
Old 12-09-2009, 09:10   #7 (permalink)
jufong's Avatar
Member: 120908
Thanks Meter: 37
for imei infi can't fix that
maybe z3x of furius blink can do that
The Following User Says Thank You to jufong For This Useful Post:
6300 sim card registration failed!!! ..::khaled::.. Nokia Hardware & Hardware Repair 16 07-19-2011 17:00
KG130 Sim Card Registration failed after UNLOCK kushstha VygisToolbox 3 02-13-2009 12:20
nokia 6288 sim registration fail after nobrand flash leecom72 Nokia Hardware & Hardware Repair 0 09-16-2008 22:09
sim card registration failed after sucessful unlock Olegas BB5BOX 7 04-09-2008 15:42
Page generated in 0.34926 seconds with 8 queries
