11-29-2008, 12:16 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Pakistan (Layyah) Punjab Age: 37
Member: 453862 Status: Offline Thanks Meter: 53 | KG 195 Shut off in standby/sleep mode but when we play games or play adudio or video it is ok and not shut down I format it complete and repaired imie but the same plz help me thanks |
11-29-2008, 14:32 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, We never heard about this problem. You can try to flash phone, but if you will see the same problem after flashing you have a reason to check phone hardware. |
12-24-2008, 08:00 | #4 (permalink) |
Insane Poster Join Date: Dec 2007
Member: 655795 Status: Offline Thanks Meter: 3 | Till now no way to solve this There is no any solution for this problem in the infinity box i have tried everything flashed the phone after erase and also tried the both formate methods but problem is still the same Team please do something for this problem |
12-24-2008, 08:13 | #5 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
You are wrong ! You did not tried anything ! As I can see you write something without any explanation. I suggest you read more here: https://forum.gsmhosting.com/vbb/f296/kg-195-shut-off-standby-sleep-mode-639873/ Also, did you tried to read current thread name ? Please, post here thread name and then we will see what you talk about, what you have tried and why you say strange words instead of explain problem well. | |
05-26-2009, 09:08 | #6 (permalink) |
No Life Poster Join Date: Aug 2006 Location: P A K I S T A N(+923149818013) Age: 33
Member: 326871 Status: Offline Sonork: down2 sky.up 2 the earth Thanks Meter: 636 | disable sleep mode,,, set will be ok. but u have to do it every time you on mobile. because till now this is the solution. |
05-26-2009, 09:22 | #7 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,425 | Quote:
i also faced with same problem , but its not solved so i give back to phone to customers and yes if we disable sleep mode then mobile will ok but this is not permanent solution !! BR Faisal_Computer | |
05-26-2009, 09:40 | #9 (permalink) | |
maybe infinity support/developers can do it cause they are really hardworking guys Br Faisal_Computer | |
05-26-2009, 11:59 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, If you are sure that phone hardware is Ok, I think it may be phone firmware bug (factory firmware has a bug). It's just an idea, I do not have any confirmation. You can try to flash phone with another firmware from support area and see results. |
05-26-2009, 12:11 | #12 (permalink) | |
05-26-2009, 12:27 | #13 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Kabul Afghanistan
Member: 687312 Status: Offline Thanks Meter: 290 | Quote:
WBR Nawab Sahoo | |
LG KG 195 not listed in 2.0.8.3 ??? | anyfones | HWK | 1 | 03-29-2009 21:09 |
sagem my v55 goes off when on sleep mode | barthosyn | Sagem Hardware Repair Area | 6 | 11-01-2008 10:27 |
White Light and shut off in DCT4 WD2 phones | 1amigo | Nokia Hardware & Hardware Repair | 1 | 08-03-2006 09:04 |
