Old 08-29-2008, 15:45   #1 (permalink)
PRIMACELL's Avatar
Member: 427685
Thanks Meter: 103
kg 200 restart with simcard
COM6 selected
Action: reset settings
Model: LG-KG200
Checking data, wait...
19200 autodetect
Initializing[6219:8B02:8B01]...
CPU: MT6219
chip: 0031:BAC1:B902
CPU: MT6226MA detected
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6219B,E02,
Date: 2005.04.12
Version: 1.0
Version: 7S7330TH-001-R1D
Version: EP1
60 byte(s) read
imei: 35282701320239
connection Ok
building list...
done
items to clear: 184
warning: wrong packet cs
184 of 184 items cleared
building list...
done
0 items remains
Finished, time used: 31 sec
Remove/Install battery now !------any solutions ????
Old 08-29-2008, 15:53   #2 (permalink)
Member: 130995
Thanks Meter: 35,228
Hello,
Did you tried to make 112/emergency call without sim card ?
Old 08-29-2008, 15:53   #3 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Thumbs up Problem Solved 100%
format full ffs fone with backup of eeprom file..
Good luck...................
Old 08-29-2008, 15:57   #4 (permalink)
PRIMACELL's Avatar
Member: 427685
Thanks Meter: 103
Originally Posted by InfinitySupport View Post
Hello,
yes the phone is death when i use it for 112 call,then manually i can power on again
Old 08-29-2008, 17:01   #5 (permalink)
Member: 318781
Thanks Meter: 50
format whole flash chip
flash with good eprom and flash all ok
Old 08-29-2008, 17:11   #6 (permalink)
Umair Rashid's Avatar
Member: 421117
Sonork: +92 346 5544377 (PHONE)
Thanks Meter: 2,522
then it would be the fault of pa
Old 08-29-2008, 18:54   #7 (permalink)
Member: 130995
Hello,
You must check phone hardware, it's hardware fault.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 08-30-2008, 04:05   #8 (permalink)
PRIMACELL's Avatar
Member: 427685
Thanks Meter: 103
i had flashed,,format all,update eeprom,but phone still remain in original state,yes 100 % HARDWARE FAULT becuse that phone already repaired by thousand hands,thank all
Old 08-30-2008, 05:01   #9 (permalink)
..:::Gsm india:::..'s Avatar
Member: 380464
Thanks Meter: 141
clean phone with ctc and heat up your problem is salve i am 2 pc tested
Old 08-30-2008, 08:56   #10 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
this is eprom problem flash with good eprom and flash
Old 08-30-2008, 12:34   #11 (permalink)
Member: 130995
@maanarman
Please, check previous messages in current thread.
kg 290 restart with sim GSMBALOCH Infinity-Box 3 07-31-2009 11:07
kg 110 restarting with sim eswar7983 Infinity-Box 7 04-26-2009 10:25
d820 restart with simcard after unlock msl security patric UST Pro II 22 11-19-2008 03:10
lg kg 200 restarting hussainafridi VygisToolbox 1 10-08-2008 14:13
LG KG 195 restart with sim card solution Rise LG 0 09-06-2008 14:09
Page generated in 0.17737 seconds with 9 queries
