Old 10-29-2008, 03:35   #1 (permalink)
Member: 324674
Thanks Meter: 4
kg 220 dead after flash....
i have lg kg220...the problem is sometimes it hang.....so itry to flash it with infinity but now its dead.....
i tried all flashfile at support area but no luck.....
heres log....can someone help me to revive this phone....
COM8 [VCP2] selected
Device: LG-KG220
Checking data, wait...
advanced flash detection active
Action: flash write
Write: Firmware (code)
Skip: File system
Skip: Alchemy data
Skip: Eeprom
"smart write" enabled
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 89881500010001:89881500000000
flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb
Boot Done
Set baud...
115200
Set baud Done
Check flash...
current eeprom imei: 359101009736516
file saved: C:\Program Files\InfinityBox\LGA\eeprom_359101009736516_LG-KG220_20081029-095815.B1E.bin
version: 515-03V10iESAKG220P40FL
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
flash: 90009000000000:90909000000000
error: wrong write first sector at 0x00000000
Write Fail
Finished, time used: 1133 sec
Remove/Install battery now !
Old 10-29-2008, 04:18   #2 (permalink)
Member: 324674
Thanks Meter: 4
anyone can help me??????
Old 10-29-2008, 10:15   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
You can try to use another flash file.
Also you have a reason to rehot/reball phone flash chip.
Old 12-24-2008, 10:33   #4 (permalink)
Member: 18948
Thanks Meter: 53
no need to do that. Infinity always givving problem on LG flashing. Even with brand new set. ... stupid advertizing deleted ...
Last edited by InfinitySupport; 12-24-2008 at 18:53. Reason: stupid advertizing deleted
Old 12-24-2008, 18:52   #5 (permalink)
Member: 130995
@tanim_1976
You are completely wrong !
There is a problem with flashing one or two LG models but our programmers checking it now.
If you really have a problem just post here problem explanation with operation logs an we will try to help you to solve the problem but if you just say "all is bad" you are just a liar !
We do not like liars, please, remember this !
Your message was edited due to stupid advertizing of other tools is not allowed in Infinity-Box support forum !
Old 12-26-2008, 13:16   #6 (permalink)
master_t2's Avatar
Member: 321796
Thanks Meter: 65
Device: LG-KG220
Action: flash write
Skip: File system
Skip: Alchemy data
Skip: Eeprom
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check flash...
Check flash Done
Check space...
Check space Done
Check parameters...
Erase...
Erase Done
Write...
Write Fail
same problem.................................pls do somthing
Old 12-26-2008, 13:58   #7 (permalink)
Member: 130995
@master_t2
What is "same" problem ?
Old 12-26-2008, 14:03   #8 (permalink)
master_t2's Avatar
Member: 321796
Thanks Meter: 65
Old 12-26-2008, 15:59   #9 (permalink)
Member: 130995
Hello,
What LgA version you have used ?
KG-110 dead after flash aminnovelty Infinity-Box 9 01-16-2009 05:28
kg 275 dead after flash unlock ras FuriousGold 6 11-26-2007 15:52
KG 300 dead after Format FFS ...... .::BHATTI::. Infinity-Box 4 11-19-2007 09:45
kg 800 dead after flash ahmertelecom FuriousGold 4 09-28-2007 22:30
lg kg 110 dead after falsh chiragp Multi-Box 3 05-02-2007 12:47
Page generated in 0.25615 seconds with 9 queries
