06-29-2007, 18:29 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Kg110 Daed On Flashing ----------- PHONE I RECEIVED WITH LOCKED AFTER successful UNLOCK i checked call failed and imei corrupt after write full flash with veron 10d phone become dead but with 10a white screen and some black spot on lcd flashing log COM1 [Serial0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Write: Eeprom Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200 flash: FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 01227E22212200 flash: FEEA0000000000 Write: Alchemy data flash: 01227E22212200 flash: FFFFFF00000000 Write: Eeprom flash: 01227E22212200 flash: FEEA0000000000 Write Done Finished, time used: 1148 sec Remove/Install battery now unlock log not saved |
06-30-2007, 07:25 | #3 (permalink) |
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | same problem after write repaire eeprom(tested all three repair eeprom) anso tested with both firmware(with 10d firmware not even white screen totaly dead) COM1 [Serial0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Skip: Firmware (code) Skip: File system Skip: Alchemy data Write: Eeprom Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200 flash: FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Eeprom flash: 01227E22212200 flash: FEEA0000000000 Write Done Finished, time used: 32 sec Remove/Install battery now ! i forget to write-power on sound is ok but automatically restart and white screen any other solution? |
06-30-2007, 19:54 | #7 (permalink) | ||
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Quote:
so i hope it can be repair with software this set is in my hand till alive if you need more details i can give you by messanger so plz help me for next step tq | ||
07-04-2007, 16:39 | #8 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Back to GSM from AV
Member: 325999 Status: Offline Thanks Meter: 113 | Quote:
REGARDS | |
07-04-2007, 19:42 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! must be exist some other versions for this phone. if anyone have such phone please read out flash and send us. we will upload in on support area and maybe this one will help to fix problems |
07-05-2007, 14:27 | #10 (permalink) | |
phone powered on but still imei 10800003?000 plz help me to repair here is the flash file i uploaded http://www.mygsmindia.net/support/me...010%202007.rar | |
07-05-2007, 19:43 | #15 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: Sousse /trockadero/TUNISIA
Member: 193003 Status: Offline Thanks Meter: 46 | this what you need...to reveive your phone Quote:
you must dissamble the phone you will find a small ticket where its write the original version of the phone that you have ..you need to write or to flash with the same version..sur your phone will be ok... ..testeed..and thanks to my friend RIADH | |
KG110 Button on/off jumpers | Rashid Anwar | LG Hardware Repair | 0 | 12-06-2008 16:23 |
kg110 power on problem | chhatwaltelecom | LG Hardware Repair | 8 | 06-30-2008 13:20 |
my KG110 dead on vygis help pls..... | cora | VygisToolbox | 5 | 03-12-2007 22:25 |
