Old 02-12-2009, 18:23   #1 (permalink)
tom313rd's Avatar
Member: 436045
Sonork: 1581208
Thanks Meter: 31
Kg110 IMEI 000000000180818000
Hello there Infintiy team..
I got Lg Kg110 with this strange imei. When i enter *#06* fone gives this
IMEI SV
00000000180808000
I changed Imei too but nothing worked out..
how to fix it?
Br,
Tom @ Future Fones
Old 02-12-2009, 18:29   #2 (permalink)
BHARGAV's Avatar
Member: 126000
Sonork: 100.1593044
Thanks Meter: 110
go support area download fll flash file
go support area download fll flash file with inclde show imei flash with that file i tested 100% working
The Following User Says Thank You to BHARGAV For This Useful Post:
Old 02-12-2009, 18:56   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,401
IMEI SV
00000000180808000
how to fix it?
Br,
Tom @ Future Fones
Hello,
C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\Repair_imei_LG-KG110.txt
Old 02-12-2009, 18:57   #4 (permalink)
reaz.com's Avatar
Member: 310155
Thanks Meter: 1,304
Solution is here : C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ Repair_imei_LG-KG110
The Following User Says Thank You to reaz.com For This Useful Post:
Old 02-12-2009, 19:47   #5 (permalink)
tom313rd's Avatar
Member: 436045
Sonork: 1581208
Thanks Meter: 31
can u upload the file plz?
Wbr,
Old 02-12-2009, 20:06   #6 (permalink)
Member: 130995
Wbr,
Hello,
How to repair 000... (all zeroes) imei for LG KG-110:
1. Download files from support area folder: \flashfiles\LG\KG110\full_flash
2. Read instruction How_to_write_full_flash.txt
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 02-14-2009, 13:48   #7 (permalink)
tom313rd's Avatar
Member: 436045
Sonork: 1581208
Thanks Meter: 31
I tried full flash but Imei was still strange ..
I flashed it wiv
KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453.B1M.bin
n now the fone is all okkkk
here's the log
COM4 [VCP0] selected
module v1.36
Device: LG-KG110
Checking data, wait...
Action: flash write
Write: Firmware (code)
Skip: File system
Skip: Alchemy data
Skip: Eeprom
"smart write" active
Boot ...
Connecting, wait...
Release Power button now !
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 355995016533764
current otp imei: 300000000000000
file saved: C:\Program Files\InfinityBox\LGA\eeprom_355995016533764_LG-KG110_20090214-172119.B1E.bin
version: 602-03V10b20KG110P40
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
flash: 01227E22212200:00000100000000
write: 2nd chip area
Write Done
Finished, time used: 1396 sec
Remove/Install battery now !
The Following User Says Thank You to tom313rd For This Useful Post:
KG110 IMEI Rebuild Failed PASSIONATE_BOYS Infinity-Box 12 07-15-2009 23:40
Lg Kg110 Imei 000000 reaz.com Infinity-Box 24 07-12-2009 19:27
KG110 IMEI corupted Johnybye ULT PRO 5 10-29-2007 10:35
Lg Kg110 Imei Corrupt PASSIONATE_BOYS Infinity-Box 3 09-25-2007 20:30
lg kg110 imei crupted rajeshbahri LG 1 06-13-2007 09:55
Page generated in 0.32610 seconds with 8 queries
