07-10-2008, 08:34 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: Moldova
Member: 204684 Status: Offline Thanks Meter: 21 | KG130 blue sreen after flash I had LG KG130 with version: ***-XXV10fEURKG130P40 I flashed it with version: ***-XXV10a07KG130P40 and after that my phone sreen apear blue. I can make or recive calls but nothing hapens on the sreen. I've searched this version on support site adn I didn't find it... So what do I have to do to resolve this problem? Here is log after first flashing: Application: C:\Program Files\InfinityBox\LGA\LgA.exe Loading data, wait... [Infinity Box] v1.30 S/N: 373B:010F Wait... Current device: LG B2000 Done Current device: LG KG130 Loading file v.02... KG130P40-07-v10a_***-XX_MAY-14-2007_code[1].B1M.bin loaded Loading file v.02... KG130P40-07-v10a_***-XX_MAY-14-2007_alchemy[1].B1P.bin loaded Testing COM1 at 921600... COM1 [Serial0] selected error: can't open COM1 COM8 ready Testing COM8 at 921600... COM8 [VCP0] selected Device: LG KG130 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 3553110***xx024 current otp imei: 3553110***xx024 file saved: C:\Documents and Settings\gR\Desktop\eeprom_3553110***xx024_LG KG130_20080709-170952.B1E.bin ....... version: ***-XXV10fEURKG130P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 Write: Alchemy data flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 576 sec Remove/Install battery now ! |
07-12-2008, 11:22 | #10 (permalink) |
Member: 204684 Status: Offline Thanks Meter: 21 | ...and I made this thread ONLY after I tryed ALL versions on support. only once on the screen apeared something normal. But the phone hang up and after that (no matter what I did) sreen is blue again. And than I had made this thread. |
07-12-2008, 11:43 | #12 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | just a question for repair ffs files where to load it in eprom files icon or ffs icon because the extension .bin not included in ffs icon i use all files option in ffs icon to load ffs repair files |
07-13-2008, 08:05 | #14 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Ukraine
Member: 289200 Status: Offline Thanks Meter: 219 | Maybe try to open phone and check what version must be in phone(label on flash IC) Because for example C1100 have two different firmmwares type- 1xx and 2xx And when you write 1xx to phone with 2xx you get working phone with blue screen. |
07-13-2008, 17:53 | #15 (permalink) | |
Member: 204684 Status: Offline Thanks Meter: 21 | Quote:
I'll post results tommorow. thanks | |
vodafone 226 blue light on sreen after flash | hishamalrife | FuriousGold | 4 | 11-01-2008 15:25 |
X820 white sreen after flash | borkoi | Trident/AGERE Platform | 9 | 05-19-2007 02:17 |
T610 Blue Screen after Flash !! | Syed | Sony Ericsson | 17 | 05-07-2004 00:52 |
7210 blue screan after flash | manijak | Nokia Digital Core Technology 4 ( DCT-4 ) | 8 | 03-23-2004 07:34 |
Panasonic GD93 with blue led after flashing... :( | s.Mobi | Panasonic | 3 | 10-18-2002 06:36 |
