12-05-2007, 08:55 | #1 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 439 | kg130 unlock problem Device: LG KG130 Checking data, wait... advanced flash detection active Action: unlock unlock method: enhanced Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:4F000B00000000 error: no any expected answer: wrong answer after chip cfi request flash: 01227E22212200:4F000B00000000 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current otp imei: 355311010958090 file saved: backup_eeprom__LG KG130_20071205-111851.B1E.bin ....... version: 208-20 V10b 33 KG130P40FL Check flash Done Check space... warning: Probably wrong model selected or unknown eeprom structure, Are you sure you want to continue ? Check space Fail Finished, time used: 38 sec Remove/Install battery now ! ------------------------------------------------------------- i ask me a question about if i can continue then i press non in case there might have a problem.... WHAT i should do please advice. i have try both unlock method - enhanced/ standard |
12-05-2007, 12:12 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! make backup and you will be able to restore phone to original state later. after this done- you can try to continue with "unknown eeprom structure" |
LG KG130 unlock with hwk but no network | denard | HWK | 1 | 06-04-2013 11:47 |
LG KG130 unlock problem | Enki69 | Infinity-Box | 9 | 08-04-2010 12:31 |
kg130 unlock problem | whiteribbon | VygisToolbox | 6 | 01-29-2009 08:15 |
LG KG130 unlock | vasion | FuriousGold | 8 | 08-02-2007 10:34 |
kg130 unlock what type of cable | smootny | VygisToolbox | 1 | 07-02-2007 21:41 |
