Old 05-25-2008, 12:13   #1 (permalink)
Kanwalgee's Avatar
Member: 68392
Sonork: 100.100701
Thanks Meter: 658
KG195 Flash With Infinity ok but?
I try to flash with infity box now set is dead (before hang on startup) only 1 flash file avail on support i also try to wite backup eerom but same don,t have flash backup if any one have good backup for KG195 then share please.
Thanks in advance
Old 05-25-2008, 12:31   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Make "format ffs", no need to write another firmware or eeprom.
Old 05-25-2008, 12:49   #3 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Yes dear,
U have to no need to flash the phone.
After Format FFS u r phone will be OK. (I try too many phone & No need to flash the phone.)
OK dear phone is not on @ moment . . . .
Then long press power button. (Approximetely 1 min) It is work some time.
Post result.
Old 05-25-2008, 12:50   #4 (permalink)
Kanwalgee's Avatar
Member: 68392
Sonork: 100.100701
Thanks Meter: 658
I do it after flash but same.also try before flash but same as it.
Old 05-25-2008, 14:13   #5 (permalink)
Member: 130995
Hello,
Did you checked battery voltage ?
Also if phone was hang at startup there is a big chance that it's hardware problem.
SE K510 flashing with SETool OK, but not power ON aryasa Sony Ericsson 9 06-29-2009 07:33
Kg195 Flash With Infinity But.........help sairat Infinity-Box 10 02-04-2008 18:48
6100 flash with UFS3 OK!! BUT !!!! wina rahman Nokia Hardware & Hardware Repair 3 02-06-2007 13:41
i have problem mybe any wan can solved it if i open any soft for infinity ok but if i gsm4libya Infinity-Box 2 05-01-2006 11:56
Page generated in 0.13061 seconds with 9 queries
