02-18-2009, 09:41 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: Shoaib Electronics
Member: 515273 Status: Offline Sonork: 100.1573940 Thanks Meter: 339 | KG195 Light Off Set Will Be Restart?????? LG KG195,Working fine when I am using (OPERATE) Light off set will be restart Emergency call 112 without sim (Call Ended) Anyone who successfully solve this problem Please help me Thanks in advance |
02-18-2009, 10:13 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
1. Run ChineseMiracle software 2. Select model "MT6228 NAND" 3. Make "format" by "whole flash chip" method 4. flash phone | |
The Following 2 Users Say Thank You to deepakgarg For This Useful Post: |
02-18-2009, 12:02 | #3 (permalink) |
No Life Poster Join Date: Jan 2002 Location: 24° 51′ 36″ N, 67°
Member: 8353 Status: Offline Sonork: 113276 Thanks Meter: 335 | first three steps of deepakgarg are enough no need to flash...........tested by me many times |
The Following 4 Users Say Thank You to ASHIF For This Useful Post: |
03-16-2009, 14:03 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | performed all 4 steps process completed but same problem no luck for me mianlinks |
The Following User Says Thank You to mianjabbar For This Useful Post: |
03-16-2009, 14:18 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, What is th problem with your phone exactly ? p.s. in future any thread with problem description like "the same", "still same", "same problem", "not work" etc. will be closed due to we can not help if we do not see any problem explanation |
03-21-2009, 14:32 | #7 (permalink) |
Freak Poster Join Date: Apr 2007
Member: 489248 Status: Offline Thanks Meter: 37 | hi all i have lg kg195 and kp220 when i connet a charger after 10 sec bad connet charger i change her battery and charger too but same prob anyone help me plzzzzzzzzzzzzzz |
The Following User Says Thank You to askarimobile For This Useful Post: |
03-21-2009, 18:29 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Did you tried to format ffs and check charging after this operation ? |
05-12-2009, 18:38 | #9 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Larkana Sindh Pakistan Age: 40
Member: 600691 Status: Offline Thanks Meter: 29 | Originally Posted by dil_PAKISTANI Hello forum, LG KG195,Working fine when I am using (OPERATE) Light off set will be restart Emergency call 112 without sim (Call Ended) Anyone who successfully solve this problem Please help me Thanks in advance i sove that throo hardware 11%%%%%%%%%%%%%%%%%%%%%%%%%%%% |
The Following User Says Thank You to asif khokhar For This Useful Post: |
05-12-2009, 20:39 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It may be software or hardware fault, so it is need to check phone hardware and make "format" operation too. |
05-21-2009, 11:30 | #11 (permalink) |
No Life Poster Join Date: Oct 2005 Location: pakistan
Member: 188374 Status: Offline Sonork: 1000.2 Thanks Meter: 203 | Yes yes 100%%%%%%%%%%%%% solved. YES YES 100%%%%%%%% Solved Restart Problem Kg 195 With Hardware. |
The Following 2 Users Say Thank You to papoo For This Useful Post: |
06-19-2009, 12:31 | #13 (permalink) | |
Freak Poster Join Date: Mar 2008 Location: Quetta
Member: 728887 Status: Offline Sonork: 100.1625878 Thanks Meter: 18 | Quote:
you phone will bii work with Sim card 101%% | |
08-20-2009, 07:16 | #15 (permalink) | |
Freak Poster Join Date: Mar 2005 Location: india Age: 55
Member: 125424 Status: Offline Thanks Meter: 21 | Quote:
after flash 5.write good eeprom 6. repair imei 100%%%%%%%%%%%% set will ok thx post results | |
E251 lcd light off set fully hang | MR.MAMUN | UST Pro II | 4 | 02-08-2011 14:13 |
KG195 lights off restarting phone | urromeo | Infinity-Box | 8 | 07-15-2010 15:20 |
w350 if make call set lights will be off | goherabbas | Sony Ericsson Hardware Repair | 0 | 02-06-2010 15:31 |
nokia 1200 network sarch will be restart plz | WHED | Nokia Hardware & Hardware Repair | 7 | 04-11-2009 07:18 |
