10-08-2009, 13:27 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | KG200 LG Logo than goes off Also flash with new file & repair eeprom/ffs. ZubairArain |
10-08-2009, 14:04 | #2 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Dubai
Member: 703206 Status: Offline Sonork: 100.1601193 Thanks Meter: 412 | Quote:
1. Run ChineseMiracle software 2. Select model "MT6228 NAND" 3. Make "format" by "whole flash chip" method power on long if not work then flash 100% solution | |
The Following User Says Thank You to gsmsmile For This Useful Post: |
10-09-2009, 06:32 | #5 (permalink) |
Member: 751908 Status: Offline Thanks Meter: 186 | Log screenshot is here.. http://www.ziddu.com/download/6838507/KG200.JPG.html Log is here. COM4 [VCP0] selected module v2.93 Device: Autodetect 6228-6229 NAND Checking data, wait... Action: erase NAND flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 high speed boot On detected CPU: MT6226MA chip: 0031:0CFE:BC94 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 0B loader: 3.0840.00.00 NAND id: 00000000 external ram: 00400000 finalize connection... done NOR: 0098:004900000000 [01000000] NAND: 0000:000000000000 [00000000] NAND chip is not installed Initialize Fail Finished, time used: 32 sec Remove/Install battery now ! What is solution NOW. ZubairArain |
10-09-2009, 12:25 | #6 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: in heart of innocent peoples Age: 34
Member: 407782 Status: Offline Sonork: 100.1586820 Thanks Meter: 1,052 | Quote:
here is logo COM4 [VCP0] selected module v2.90 Device: LG-KG200 Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware KG200P64-07-V10h-000-00_MAY-22-2008_ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7331RU00-001-R1D_En_Ru_Kz_Ua.A3M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs KG200_repair_eeprom_03.A3E.bin ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:E241:A428 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 04 ver. sw 1: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7T-7330-BFRA-6-061110.BIN ver. sw 2: 7T-7330-BFRA-6-061110, 00000000 ffs offset/size: 00E00000/00200000 ffs address assigned: 00E00000 detect device sec info... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: LG-KG200_ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7T-7330-BFRA-6-061110__ffs... file saved: C:\Program Files\InfinityBox\MModule\New Folder\LG-KG200_ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7T-7330-BFRA-6-061110__ffs_20091008-170618.A3E.bin Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Firmware flash: 98004900000002:29EA0000000000 Write: Firmware Area: Eeprom/ffs flash: 98004900000002:29EA0000000000 Write: Eeprom/ffs detect device sec info... . detect device sec info finished Write Done Finalization ... Finalization Done Finished, time used: 1758 sec Remove/Install battery now ! | |
kg200 startup lg logo off | faisal4friend | Infinity-Box | 10 | 08-07-2010 10:46 |
KG200 Powered OFF with LG Logo | ZubairArain | Infinity-Box | 2 | 10-10-2009 10:46 |
LG KG200 LG LOGO Diaplay Only then Off | ASHRIFF | Infinity-Box | 18 | 10-26-2008 15:14 |
lg kg180 ,set goes off and show" inser battery" while connecting charger | smarttech | LG | 0 | 07-29-2008 05:11 |
V300 power on moto logo then goes off | saarcgsm | Motorola P2k | 0 | 03-06-2007 14:40 |
