05-08-2010, 09:37 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | KG200 Powered Off after LG Logo! 1. Format ffs.... COM5 [VCP0] selected module v3.38 Device: LG-KG200 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:E073:2296 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330SA00-001-R1D.BIN project-id: 7S7330SA00-001-R1D, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98004900000002:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98004900000002:29EA0000000000 Finalization Done Finished, time used: 1 min 7 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! 2. Format Whole Chip with ChineseMiracle selecting NAND chip. COM5 [VCP0] selected module v3.13 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6219:8B02:8B01 status: FF bbchip bl ver: FE NOR flash id[005D]: 0098:004900000000 [TOSHIBA] TV00578002DABD chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00010000 NAND flash id[0043]: 0098:00F000800095 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00047000 external RAM [HW_RAM_SRAM, CS1] size: 00400000 done Set baudrate (115200)... done interesting cpu type found: 6219:8B02:8B01 ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/04000000 ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7330SA00-001-R1D detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330SA00-001-R1D.BIN project-id: 7S7330SA00-001-R1D, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: incorrect header: C06380CA8BD5FC4BE4341B146AD1EAD8 warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format (HW_STORAGE_NAND)... Disconnect... done Finished, time used: 1 min 44 sec Remove/Install battery now ! 3. Repair / Change IMEI. Action: "repair imei" Model: LG-KG200 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 135790246811220 imei write method: mode-1 new imei-1: 353923031112408 verification Ok Finished, time used: 4 sec Remove/Install battery now ! |
The Following User Says Thank You to ZubairArain For This Useful Post: |
05-08-2010, 12:38 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | How to fix LG KG195, KG200, KG300 freez/restart etc.: 1. Run "ChineseMiracle" software 2. Select model "MT6228 NAND" 3. Make "format" by "whole flash chip" method 4. repair imei |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
05-10-2010, 09:05 | #7 (permalink) |
Member: 751908 Status: Offline Thanks Meter: 186 | COM5 [VCP0] selected module v3.13 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: erase whole flash chip interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6219:8B02:8B01 status: FF bbchip bl ver: FE NOR flash id[005D]: 0098:004900000000 [TOSHIBA] TV00578002DABD chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00010000 NAND flash id[0012]: 0098:007600A500C0 [TOSHIBA] TC58DVM92A1FT chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00047000 external RAM [HW_RAM_SRAM, CS1] size: 00400000 done Set baudrate (115200)... done interesting cpu type found: 6219:8B02:8B01 ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/04000000 ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7330SA00-001-R1D detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330SA00-001-R1D.BIN project-id: 7S7330SA00-001-R1D, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detect NAND info... number of areas/bytes to read: 1:00010000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: incorrect header: B549E4EFB512F4B38F87A3060570DF73 warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format (HW_STORAGE_NAND)... 00000000-03FFFFFF... Disconnect... done Finished, time used: 1 min 3 sec Remove/Install battery now ! After this Phone stuck on LG Logo. |
05-11-2010, 18:10 | #10 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | If phone freez after this operation I suggest you check phone hardware, it may be that NAND flash chip is damaged or bad soldered. |
07-08-2010, 12:55 | #11 (permalink) |
Freak Poster Join Date: May 2010 Location: Tebing Tinggi
Member: 1306699 Status: Offline Sonork: GC Thanks Meter: 21 | without simcard,my phone can standby but if with simcard,it auto off after LG logo i already try "format" by "whole flash chip" method is it hardware ??? |
07-11-2010, 18:11 | #12 (permalink) | |
It may be software or hardware problem. Check this: Can not make a call - Infinity-Box | |
04-22-2011, 23:54 | #13 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1387494 Status: Offline Thanks Meter: 0 | i have lg 300. its start normaly but when i make a call from this its gone on standby and come again after 15 sec. and shows searching on display. is that hardware problem? need little attention from experts. |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
Operator-Logo for 5110 | MiMiR the WiseMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-25-1999 15:50 |
For Jefferson -6110 goes off itself | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-19-1999 21:28 |
