09-20-2008, 14:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: i dont know. where i am Age: 35
Member: 745728 Status: Offline Sonork: 100.1579942 Thanks Meter: 338 | nokia 5310 express music ................. Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:7003:0009 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.3FEB6239.[MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_LCD2_132 _080522.BIN_98BD6122].rpl ==================== New firmware detected: MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_LCD2_132 _080522.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 3FEB6239 identification#1 protocol ver: 04 ver. sw1: MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_LCD2_132 _080522.BIN ver. sw2: A521_L8EN_LCD2_132_080522, DD9E4267 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_LCD2_132 _080522.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_LCD2_132 _080522.BIN]_20080920-185806.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_3FEB62 39_MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_LCD2_ 132_080522.BIN_98BD6122_20080920-185834.B0X.bin Finished, time used: 143 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time format ok but not power on now i need full flash file for this set.pls help me |
09-21-2008, 16:47 | #4 (permalink) |
Freak Poster Join Date: Jun 2005 Location: Karor lal eason Age: 43
Member: 151792 Status: Offline Thanks Meter: 15 | COM7 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:8403:0009 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 115 sec Remove/Install battery now ! earlier i flashed with orignal backup, then format in safe mode, then the result arrived is upper |
09-22-2008, 20:59 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! backup your existing firmware and try following: flashfiles/ChineseMiracle/_MT6225/MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_108_0801 23___5310_16m_En_Ru_Fr_Es_Th_Vn_Farsi_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6225/MTK25_06B_PCB01_GPRS_MT6225_S00.A521_L8EN_116_0803 12_Nokia-5300-XpressMusic_16m_En_Ru_Fr_Id_Th_Vn_Farsi_Ar.B0M.bin |
nokia 5310 express music restart | umesh garg | Nokia Hardware & Hardware Repair | 19 | 03-02-2011 18:49 |
can I unlock nokia 5310 express music locked with movistar spain? | MR.PRESIDENT | Gsmfather The Wholesale Unlocking Database | 2 | 11-01-2008 06:07 |
nokia 5310 express music : DCT4 or BB5? | aao1308 | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 10-29-2008 15:42 |
Where can unlock Nokia 5310 Express Music on T-Mobile (Austria)?? | agabey1905 | Universalbox | 0 | 04-22-2008 16:15 |
