05-21-2007, 08:45 | #5 (permalink) |
No Life Poster Join Date: Jul 2004 Location: PakLink.org
Member: 71321 Status: Offline Sonork: 100.1576579 Thanks Meter: 428 | I Can't Conect My Mobile With Box Which Poret Need To Use For Conect Rj 45 Cable Of Kg200? I Use New Infinity Slim Plus With Sim Card If Use Rj 45 Conecter From Box Then Which Come Port I Need To Select ? Or Need To Use With Unibox? |
10-07-2007, 14:19 | #7 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Indonesia
Member: 69608 Status: Offline Thanks Meter: 63 | already read manual,but never connect using cable RJ45 G50/i-Mobile 510 MM Module 1.62 always show error like this COM10 [VCP0] selected Device: LG KG200 Checking data, wait... advanced flash detection active Action: read eeprom Boot... Press and HOLD Power button now ! baud autodetection active 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 5 sec Remove/Install battery now ! Which cable are work for this phone???rx--tx already switch all information in forum already try but not work, need realy solution from infinity support on this phone thanx.... |
10-07-2007, 14:56 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | You have used wrong cable ! You must use cable that must be used but not cable that you want to use ! Start "Shell", select model "KG200" and see correct cable description ! |
10-07-2007, 16:37 | #9 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Live in your Heart
Member: 71045 Status: Offline Thanks Meter: 19 | sucessfully repair kg 200 and kg300 just now by using the pinout given in shell phone was blinking while power on only format ffs log of repair phone is given below Do you want to continue ? Action: reset settings Model: LG KG300 Checking data, wait... COM8 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6227:8A02]... Connecting, wait... Release Power button now ! Phone detected, wait... warning: wrong packet checksum imei: 35283401150277 warning: wrong packet checksum warning: wrong packet checksum warning: wrong packet checksum warning: wrong packet checksum 193 of 207 items cleared 10 items remains Finished, time used: 62 sec Remove/Install battery now ! kg 200 Device: LG KG200 Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6219:8B02:8B01]... MT6226MA detected boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Identification... detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [standard] (or higher) generation protocol ver: 04 ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330SA00-001-R1B.BIN ver. sw2: 7S7330SA00-001-R1B ffs offset/size: 00E00000/00200000 reading [eeprom[ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330SA00-001-R1B.BIN]]... file saved: backup_eeprom[ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330SA00-001-R1B.BIN]_20071007-202011.A3E.bin flash: 98004900000002:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 98004900000002:604B8800000000 Write Done Finished, time used: 86 sec Remove/Install battery now ! thanks infinity team keep it up thanks and regards ' Zafar Janjua |
10-07-2007, 17:04 | #10 (permalink) | |
Member: 71321 Status: Offline Sonork: 100.1576579 Thanks Meter: 428 | Quote:
HERE CABLE DWRING FOR U | |
kg200 unlock | celtic196721 | Z3X-Team Products | 1 | 03-04-2010 21:30 |
kg200 unlock | arshad_bhatti | LG Hardware Repair | 0 | 08-04-2009 08:05 |
LG KG200 unlock by furious-gold | gsm karachi | FuriousGold | 7 | 02-16-2008 07:22 |
lg kg200 unlock problem | burraq | Infinity-Box | 3 | 11-16-2007 16:54 |
LG KG200 unlock | GSMBALOCH | FuriousGold | 8 | 09-15-2007 07:58 |
