01-07-2008, 10:27 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: tunis,tunisia Age: 48
Member: 10396 Status: Offline Thanks Meter: 32 | kg245 flash file corrupted Current device: LG KG245 Loading file v.02... Loading failed, probably damaged data file. plz chek this file |
01-11-2008, 13:54 | #3 (permalink) |
Member: 10396 Status: Offline Thanks Meter: 32 | COM1 selected Device: LG KG245 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 350305260000001 current otp imei: 359103000136373 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35030526000000 1_LG KG245_20080111-134948.B1E.bin .................................................. .............. Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 01227E223C2200:FEEA0000000000 Write: Alchemy data flash: 90009000900090:90909000000000 flash: 90009000900090:90909000000000 error: wrong write first sector at 0x00C00000 Write Fail Finished, time used: 188 sec Remove/Install battery now ! what's the pb plz?? now phone freeze at the logo and restart. |
02-26-2008, 16:54 | #6 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: BELARUS, Minsk Age: 44
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | Quote:
==== log opened: [11.02.2008 14:17:56] ==== Application: C:\Program Files\InfinityBox\LGA\LgA.exe Loading data, wait... [Infinity Box] v1.26 S/N: 04F1:010C Wait... Current device: LG KG245 Done Loading file v.02... KG245P64-07-V10k-***-XX SEP 26 2006_CodeData_w_calibration[1].B1M.bin loaded Loading file v.02... KG245P64-07-V10k-***-XX SEP 26 2006_AlchemyData[1].B1P.bin loaded Testing COM7 at 460800... COM7 [VCP0] selected Device: LG KG245 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 0000527A Boot Done Set baud... 460800 Set baud Done Check flash... current eeprom imei: 359103002474954 current otp imei: 359103002474954 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35910300247495 4_LG KG245_20080211-142017.B1E.bin .................................................. .............. Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 01227E223C2200:FEEA0000000000 Write: Alchemy data flash: 90009000900090:90909000000000 flash: 90009000900090:90909000000000 error: wrong write first sector at 0x00C00000 Write FailFinished, time used: 59 sec Remove/Install battery now ! | |
03-02-2008, 19:00 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you still have problems with phone, please, try to use our latest Lg update: http://67.15.194.130/vbb/showthread.php?t=508247 and flash phone again. |
LG KG245 Flash File Need... | LoveLess | LG | 2 | 04-15-2008 13:02 |
W550 Flash Files Corrupt? | NUGSM | SonyEricsson (USB-Smart) | 1 | 04-14-2006 22:16 |
7610 flash files corrupt | FX1 | UFS2 + UFS3-Tornadoflasher | 0 | 12-05-2005 18:40 |
Urgent Help. E600 flash file corrupt. | Imran_Khatri | NSPRO | 18 | 06-07-2005 08:41 |
