Old 06-25-2007, 12:08   #1 (permalink)
samsoft's Avatar
Member: 90032
Sonork: 310385848
Thanks Meter: 140
Kg270 Not Unlocked
COM12 [VCP2] selected
Device: LG KG270
Checking data, wait...
Action: unlock
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check free space...
flash chip supported
sw version: ULC2GL AIRTEL KG270 P16 FL 91 V10c 404-XX Apr 30 2007 +0
Check free space Done
Check parameters...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20070625-153407.B1E.bin
Loading data...
Data loaded
imei: 3555880148xxxxxx
Reading [eeprom-sec_3555880148xxxxxx]...
file saved: backup_eeprom-sec_3555880148xxxxxxx_20070625-153408.B1E.bin
Reading [eeprom-dyn_3555880148xxxxxxxx]...
file saved: backup_eeprom-dyn_355588014xxxxxxx_20070625-153410.B1E.bin
Check parameters Done
Check memory...
Loading data...
Data loaded
Loading data...
Data loaded
Check memory Done
Write...
Erasing: eeprom-sta
Writing: eeprom-sta
Write Done
Finished, Remove/Install battery now !
Time used: 25 sec
Old 06-25-2007, 14:42   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
good log... And what is the problem ?
Did you tried to read unlock codes instead of direct unlock ?
What you see on LCD when you inser SIM card ?
Old 06-25-2007, 22:37   #3 (permalink)
Moderate's Avatar
Member: 232566
Thanks Meter: 148
@Infinity Team,
Even i tried to unlock LG KG-270 but after succesfull unlocking message the mobile is still locked.
I want to know is there any code sequence with the help of which i can unlock it.
After unlocking and all the tries even i flashed the mobile but...when i entered the sim card from different carrier i got the following message on the mobile "Invalid sim ! Please inset Origional Airtel GID A-SIM .......
Fix the Bugs Infinity team..
Reagrds,
Moderate.
Old 06-25-2007, 22:39   #4 (permalink)
Moderate's Avatar
Member: 232566
Thanks Meter: 148
Here are the LOG of all operations.
=====> FIRST TIME WHEN I TRIED TO UNLOCK DIRECTLY <======
Current model: LG KG270
Ready
Testing COM9 at 115200...
COM9 [VCP0] selected
Device: LG KG270
Action: unlock
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20070625-221855.B1E.bin
Loading data...
Data loaded
imei: 3555xxxxxxxxxxxxx
Reading [eeprom-sec_3555xxxxxxxxxxxxx]...
file saved: backup_eeprom-sec_3555xxxxxxxxxxxxx_20070625-221857.B1E.bin
Reading [eeprom-dyn_3555xxxxxxxxxxxxx]...
file saved: backup_eeprom-dyn_3555xxxxxxxxxxxx_20070625-221858.B1E.bin
Check memory...
Loading data...
Data loaded
Loading data...
Data loaded
Check memory Done
Write...
Erasing: eeprom-sta
Writing: eeprom-sta
Write Done
Time used: 21 sec
====> SECOND TIME WHEN I TRIED TO READ THE CODE <======
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20070625-222107.B1E.bin
Loading data...
Data loaded
file saved: backup_eeprom-sec_3555xxxxxxxxxxxxx_20070625-222108.B1E.bin
file saved: backup_eeprom-dyn_3555xxxxxxxxxxxxx_20070625-222110.B1E.bin
Check memory...
Loading data...
Data loaded
code: 04491251
code: 0000000000000000
Time used: 20 sec
====> THIRD TIME WHEN I TRIED AGAIN FOR DIRECT UNLOCK <=====
Device: LG KG270
Action: unlock
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20070625-222154.B1E.bin
Loading data...
Data loaded
imei: 35558801469693900
file saved: backup_eeprom-sec_3555xxxxxxxxxxxxx_20070625-222155.B1E.bin
Reading [eeprom-dyn_35558xxxxxxxxxxxxx]...
file saved: backup_eeprom-dyn_3555xxxxxxxxxxxxx_20070625-222157.B1E.bin
Check memory...
Loading data...
Data loaded
Loading data...
Data loaded
error: not locked or unknown eeprom
Check memory Failed
Time used: 17 sec
Regards,
Moderate.
Old 06-25-2007, 23:59   #5 (permalink)
Member: 130995
@moderate
1. try to flash phone with other firmware and see results
2. send me all eeprom backup files to check: [email protected]
Old 06-26-2007, 07:23   #6 (permalink)
Moderate's Avatar
Member: 232566
Thanks Meter: 148
@moderate
I did flash with other version but the problem remained same,mobile is locked.
I tried with the following code sequence 2945#*20001# but didnt't work.No menu appear for entering the unlock code.After flashing with other version i got the following message"Insert right sim" ...
and i have sent the backed up eeproms to above mentioned email id....
try to fix the problem..
Regards,
Moderate.
Old 06-26-2007, 07:37   #7 (permalink)
Member: 130995
@moderate
I have got your e-mail and will let you know about results ASAP.
Old 06-26-2007, 15:26   #8 (permalink)
Member: 130995
@moderate
I was informed by other user that unlock was Ok after flashing with non-Airtel firmware and entering readed code.
Are you sure that you can't enter unlock code after you flashed phone with non-Airtel firmware ?
Old 06-26-2007, 19:23   #9 (permalink)
Moderate's Avatar
Member: 232566
Thanks Meter: 148
@moderate
@ Infinity Team,
yes i did unlock with non airtel firmware with unlock code.
Thanks for the Support.
Regards,
Moderate.
Old 06-27-2007, 10:01   #10 (permalink)
Member: 130995
Thanks for confirmation. This information can helps to other users in case of problems. Anyway, we are working about more fast solution for Airtel KG270.
Old 11-05-2008, 10:19   #11 (permalink)
Member: 649344
Thanks Meter: 7
kg270 unlock sucessfully
kg 270 unlocked sucessfull
first flashing with firmware,lp,file system file
then unlock
and repair imei
its now unlocked
my black berry 8100 is not unlock (Answered) ravin j tejura MXKEY Blackberry Flasher and Unlocker (by Alim Hape) 11 04-08-2010 16:05
kg270 cn't unlock chris2007 FuriousGold 3 03-18-2008 12:32
lg kg270 airtel unlock help plzzz! syed.n Infinity-Box 6 01-26-2008 22:25
Kg270 sucsecssfully unlock in infinity .::AZEEM::. Infinity-Box 2 12-04-2007 12:55
kg270 not connect ravi um Infinity-Box 11 10-07-2007 16:03
Page generated in 0.36512 seconds with 8 queries
