09-10-2008, 07:51 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Maharagama, Srilanka
Member: 661090 Status: Offline Sonork: 100.1616818 Thanks Meter: 541 | KG270 sucessfully repair no service Device: LG KG270 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: ULC2GL KG270 P16 ARB V10b XXX-XX APR 09 2007 +0 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080910-124639.B1E.bin loading data... data loaded imei: 35744501520692900 reading [eeprom-sec_35744501520692900]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35744501520692900_20080910-124641.B1E.bin reading [eeprom-complete_35744501520692900]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35744501520692900_20080910-124648.B1E.bin reading [eeprom-dyn_35744501520692900]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_35744501520692900_20080910-124650.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 34 sec |
The Following 2 Users Say Thank You to jatchaminda For This Useful Post: |
12-03-2008, 15:24 | #7 (permalink) |
Junior Member Join Date: Apr 2008
Member: 758320 Status: Offline Thanks Meter: 1 | COM4 [VCP3] selected module v1.57 Device: LG-KG270 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL CIS Open KG270 KG275 P16 07 V10e XXX-XX MAY 30 200 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20081203-190609.B1E.bin loading data... data loaded imei: 35361202288630800 reading eeprom-security_35361202288630800... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35361202288630800_20081203-190610.B1E.bin reading eeprom-complete_35361202288630800... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35361202288630800_20081203-190616.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: FFS-2/File system Writing: FFS-2/File system Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 457 sec Remove/Install battery now ! but problem is same after all the thread about kg270 no service have been checked |
Full Solution For Lg Kg270 For No Service After Flash+Insert SIm error. | sahil00150 | Infinity-Box | 15 | 02-09-2011 15:55 |
How to repair no service problem | Tajammul | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-18-2010 10:54 |
Kg270 no service after flash | SOHAIL BASHARAT | FuriousGold | 9 | 01-24-2010 09:25 |
How Repair LG KG270 No Service | aswancamel | Infinity-Box | 1 | 08-04-2009 18:45 |
KG270 After Flash Signals Gone & Show NO SERVICE | dil_PAKISTANI | Infinity-Box | 1 | 09-28-2008 20:38 |
