09-15-2008, 15:36 | #1 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Newcastle,Australia Age: 47
Member: 44167 Status: Offline Thanks Meter: 17 | kg288 dead plz tell me what i ll do! Device: LG-KG288 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 45FA:1548 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... loading data... error: source buffer too small: 00000000 instead of 000001DA reading [eeprom-sec]... reading [eeprom-complete]... backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware error: set erase range error: erase failed: 00400000 Write Failed Finished, Remove/Install battery now ! Time used: 105 sec |
09-15-2008, 15:47 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
hi.. did u take backup eeprom and flash before flashing..? if not try to flash on the support... | |
09-16-2008, 21:08 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @faisal butt You must open phone and check it's hardware, f.e. clean water or replace flash chip. It's for sure hardware problem due to flash chip was detected by software incorrectly. |
Genie dead no power on... [ANSWERED] | lchico | Genie Universal | 1 | 03-29-2010 07:18 |
..::lg kg288 dead after changing charging jack::.. | HUM | LG Hardware Repair | 1 | 08-24-2009 13:14 |
LG KG288 unlock help | yekiam | LG | 1 | 12-05-2007 22:25 |
26 Nov 2007: LG KG288, KG370, KG375 models supported | InfinitySupport | Infinity-Box | 29 | 12-02-2007 14:59 |
Looking for LG KG288, KG296, KG370... | InfinitySupport | Infinity-Box | 2 | 11-26-2007 08:10 |
