kg275 direct unlock seccessfull in 17 sec COM3 [VCP0] selected Device: LG KG275 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL FR SFR KG275 P16 FL 33 V10a 208-10 JUN 22 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20071112-134014.B1E.bin loading data... data loaded imei: 35744601087127900 Reading [eeprom-sec_35744601087127900]... file saved: backup_eeprom-sec_35744601087127900_20071112-134015.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-sec Writing: eeprom-sec probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 17 sec ------------------ operator sfr france telecome select method direct unlock method #2 (airtel etc.):eek: |
Which Cable you have used? If you have used USB Cable then give me it's pinout and Drivers. Thanx in advance. |
you must use com or rj45 cable keyboard top 1.........18 12: phone Rx 13: phone Tx 18: Gnd |
second one with direct unlock COM3 [VCP0] selected Device: LG KG275 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL ORANGE FR KG275 P16 FL 33 V10b 208-01 JUN 08 2007 +1 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20071122-123118.B1E.bin loading data... data loaded imei: 35744601924148200 Reading [eeprom-sec_35744601924148200]... file saved: backup_eeprom-sec_35744601924148200_20071122-123119.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-sec Writing: eeprom-sec probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 17 sec |
same here too unlock sucessfull COM18 [VCP0] selected Device: LG KG275 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL KG270 P16 AFR V10c XXX-XX MAY 09 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20071121-183516.B1E.bin loading data... data loaded imei: 35558801005053700 Reading [eeprom-sec_35558801005053700]... file saved: backup_eeprom-sec_35558801005053700_20071121-183517.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-sec Writing: eeprom-sec probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 32 sec Loadng data, wait... Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Repair imei... software version: KG275P16-AFR-V10c-XXX-XX-MAY 09 2007+0 original imei: 35558801005053700 new imei: 35558801000000 error: imei verification failed, try again. Done Finished Loadng data, wait... Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Repair imei... software version: KG275P16-AFR-V10c-XXX-XX-MAY 09 2007+0 original imei: 35558801005053700 new imei: 35558801005053 imei verification Ok Done Finished |
thx for rapport good work infinity team |
thanks for your test report good work infinity team |
Good report thanks......... |
Thanks for your report keep it up... WBR.. GSMcracker.. |
