Old 11-12-2007, 12:46   #1 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,568
kg275 direct unlock seccessfull in 17 sec
COM3 [VCP0] selected
Device: LG KG275
Checking data, wait...
Action: unlock
direct unlock method #2 (Airtel etc.)
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check free space...
flash chip supported
sw version: ULC2GL FR SFR KG275 P16 FL 33 V10a 208-10 JUN 22 2007 +0
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20071112-134014.B1E.bin
loading data...
data loaded
imei: 35744601087127900
Reading [eeprom-sec_35744601087127900]...
file saved: backup_eeprom-sec_35744601087127900_20071112-134015.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
Erasing: eeprom-sec
Writing: eeprom-sec
probably you need to restore original imei after unlock process
Write Done
Finished, Remove/Install battery now !
Time used: 17 sec
operator sfr france telecome
select method direct unlock method #2 (airtel etc.)
Old 11-12-2007, 12:55   #2 (permalink)
Nustian's Avatar
Member: 302566
Sonork: 1579334:100.1.100
Thanks Meter: 42
Which Cable you have used?
If you have used USB Cable then give me it's pinout and Drivers.
Thanx in advance.
Old 11-12-2007, 14:13   #3 (permalink)
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,568
you must use com or rj45 cable
keyboard top
1.........18
12: phone Rx
13: phone Tx
18: Gnd
Old 11-22-2007, 11:35   #4 (permalink)
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,568
second one with direct unlock
Device: LG KG275
Action: unlock
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check free space...
sw version: ULC2GL ORANGE FR KG275 P16 FL 33 V10b 208-01 JUN 08 2007 +1
Check parameters...
file saved: backup_eeprom-sta_20071122-123118.B1E.bin
loading data...
data loaded
imei: 35744601924148200
Reading [eeprom-sec_35744601924148200]...
file saved: backup_eeprom-sec_35744601924148200_20071122-123119.B1E.bin
Check memory...
Check memory Done
Write...
Erasing: eeprom-sec
Writing: eeprom-sec
Write Done
Time used: 17 sec
Old 11-22-2007, 11:44   #5 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,392
same here too
unlock sucessfull
COM18 [VCP0] selected
Device: LG KG275
Action: unlock
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check free space...
sw version: ULC2GL KG270 P16 AFR V10c XXX-XX MAY 09 2007 +0
Check parameters...
file saved: backup_eeprom-sta_20071121-183516.B1E.bin
loading data...
data loaded
imei: 35558801005053700
Reading [eeprom-sec_35558801005053700]...
file saved: backup_eeprom-sec_35558801005053700_20071121-183517.B1E.bin
Check memory...
Check memory Done
Write...
Erasing: eeprom-sec
Writing: eeprom-sec
Write Done
Time used: 32 sec
Loadng data, wait...
Phone must be SWITCHED ON !
Connecting, wait...
Connection Ok
Repair imei...
software version: KG275P16-AFR-V10c-XXX-XX-MAY 09 2007+0
original imei: 35558801005053700
new imei: 35558801000000
error: imei verification failed, try again.
Done
Finished
Connecting, wait...
Connection Ok
Repair imei...
new imei: 35558801005053
imei verification Ok
Done
Finished
Old 11-22-2007, 12:08   #6 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
Thanks Meter: 787
thx for rapport good work infinity team
Old 11-22-2007, 17:31   #7 (permalink)
SHOEB AHMED's Avatar
Member: 161115
Sonork: Here you can find it...
Thanks Meter: 3,037
thanks for your test report good work infinity team
Old 11-23-2007, 12:07   #8 (permalink)
GSMBALOCH's Avatar
Member: 503620
Sonork: 1621694
Thanks Meter: 46
Good report thanks.........
Old 11-24-2007, 12:30   #9 (permalink)
GSMcracker's Avatar
Member: 171408
Sonork: 100.1582771
Thanks Meter: 25
Thanks for your report keep it up...
WBR..
GSMcracker..
:: World 1st, Unlock W760a in 50 sec :: SiLver GSM SETool2 33 10-02-2013 18:57
17/01/2010 Microbox Update ADD ACER S200 ! DIRECT UNLOCK ! FIRST IN THE WORLD samigsm78 Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 25 06-14-2012 09:10
w375 unlock successfull in 10 sec on multi box asif_ae Multi-Box 3 11-26-2008 01:39
i unlock 6120c in few sec great support ....... diljan_07 Universalbox 0 04-15-2008 14:37
LG KP202 direct unlock seccessfull....... SHOEB AHMED Infinity-Box 4 11-26-2007 17:07
Page generated in 0.34981 seconds with 8 queries
