11-01-2007, 10:42 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: U-A-E Dubai---->Pak
Member: 315789 Status: Offline Thanks Meter: 3,428 | KG275 unlock but Device: LG KG275 Checking data, wait... Action: unlock direct unlock method #1 Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL UK OPEN KG275 P16 FL 44 V10a 234-33 AUG 17 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20071101-013205.B1E.bin loading data... data loaded imei: 35558801049200200 Reading [eeprom-sec_35558801049200200]... file saved: backup_eeprom-sec_35558801049200200_20071101-013206.B1E.bin backup critical area Done Check memory... loading data... data loaded loading data... data loaded loading data... data loaded loading data... data loaded code: 77608066 Check memory Done Write... Erasing: eeprom-sta Writing: eeprom-sta Write Done Finished, Remove/Install battery now ! Time used: 22 sec but still insert right sim |
11-01-2007, 22:47 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Glad to hear about good results. If you still have this phone on hands, please, read flash and send to [email protected] |
03-12-2008, 22:12 | #4 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 223770 Status: Offline Thanks Meter: 49 | COM5 [VCP0] selected Device: LG KG275 Checking data, wait... Action: unlock direct unlock method #1 Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL ORANGE FR KG275 P16 FL 33 V10b 208-01 JUN 08 2007 +1 Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\LgA\kg275deux\backup_eeprom-sta_******78.B1E.bin loading data... data loaded imei: 3585****9800 reading [eeprom-sec_35858*****79800]... file saved: C:\Program Files\InfinityBox\LgA\kg275deux\backup_eeprom-sec_35858*******_20080312-220839.B1E.bin reading [eeprom-complete_358582*****79800]... file saved: C:\Program Files\InfinityBox\LgA\kg275deux\backup_eeprom-complete_3585****879800_20080312-220854.B1E.bin backup critical area Done Check memory... loading data... data loaded loading data... data loaded loading data... data loaded loading data... data loaded code: 75623112 Check memory Done Write... Erasing: eeprom-sta Writing: eeprom-sta Write Done Finished, Remove/Install battery now ! Time used: 70 sec bat no result phone steeeeeeeeeeeelllllllllllllllllll locked after entring code and reseting phone no result |
03-13-2008, 10:30 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Sometimes it's good idea to read documentation... C:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_enter_unlock_code_LG-MG160_MG161_KG270_KG271_KG275_KG276_KG278_KG288_KG 370_KG375.txt Infinity-Box How to enter unlock code LG-MG160 MG161 KG270 KG271 KG275 KG276 KG278 KG288 KG370 KG375 Phone is locked but does not as to enter code: 1. insert any wrong Sim-Card in phone 2. you will see on LCD: "insert correct sim" 3. type unlocking code and press Call "Green" button 4. wait for few seconds - phone will restart and unlocked |
03-13-2008, 13:54 | #8 (permalink) | |
Member: 223770 Status: Offline Thanks Meter: 49 | Quote:
phone steeeeeeeeel locked "insert correct sim" and after reseting with 2945#*# and entring the code and after enting code with ******#*# and send key phone steeel locked | |
03-13-2008, 14:27 | #9 (permalink) |
Member: 223770 Status: Offline Thanks Meter: 49 | COM5 [VCP0] selected Device: LG KG275 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL ORANGE FR KG275 P16 FL 33 V10b 208-01 JUN 08 2007 +1 Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\LgA\barhoumi\backup_eeprom-sta_******66.B1E.bin loading data... data loaded imei: 35858*****9800 reading [eeprom-sec_35858****9800]... file saved: C:\Program Files\InfinityBox\LgA\barhoumi\backup_eeprom-sec_358582**********13-142126.B1E.bin reading [eeprom-complete_358******9800]... file saved: C:\Program Files\InfinityBox\LgA\barhoumi\backup_eeprom-complete_35858******-142139.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-sec Writing: eeprom-sec probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 62 sec thx br for help phone unlocked with infinity with direct unlock method #2 |
kg275 UNLOCKING | kaio | FuriousGold | 6 | 01-27-2008 14:34 |
LG KG275 unlocks needed | thechachman | Phone Unlocking Codes & Maps | 0 | 12-28-2007 09:51 |
for kg275 unlock :) | bronks | FuriousGold | 12 | 12-24-2007 03:04 |
KG275 unlock error ... ! | llcoolr | FuriousGold | 5 | 11-06-2007 22:35 |
kg275 unlock | .:bono:. | FuriousGold | 12 | 09-14-2007 02:35 |
