Old 02-07-2009, 10:28   #1 (permalink)
Umair Rashid's Avatar
Member: 421117
Sonork: +92 346 5544377 (PHONE)
Thanks Meter: 2,519
kg290 got dead by infinity box.
my lg kg290 was on before flashing.
it had the fault of "restarting"
when i flashed it stops at 5% and now again stops at same time.
what would be the solution ? phone is now dead
Old 02-07-2009, 16:36   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
Please, download and install LgA v1.24 module from /software/archive folder and flash phone again.
Old 02-08-2009, 08:19   #3 (permalink)
Member: 421117
Thanks Meter: 2,519
Originally Posted by InfinitySupport View Post
Hello,
i am using v1.36 which is latest.why not working on this?
phone always stops at 5% .and it was on before flashing.
Old 02-08-2009, 08:56   #4 (permalink)
Member: 421117
Thanks Meter: 2,519
luckily i have backed up full flash before starting flashing .
so how to write back full flash inorder to revive phone?
Old 02-08-2009, 09:29   #5 (permalink)
Member: 421117
Thanks Meter: 2,519
using 1.24 ....
COM4 [VCP0] selected
Device: LG KG290
Checking data, wait...
advanced flash detection active
Action: flash write
Write: Firmware (code)
Skip: File system
Write: Alchemy data
Skip: Eeprom
"smart write" enabled
"keep calibration" enabled
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 89881600010001:89881600000000
flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb
Boot Done
Set baud...
921600
Set baud Done
Check flash...
current eeprom imei: 357456017047252
file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35745601704725 2_LG KG290_20090208-131505.B1E.bin
version: D-9DGDKG290P40
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
calibration area skipped
Write: Alchemy data
flash: 90009000900090:90909000000000
error: wrong write first sector at 0x00000000
Write Fail
error: wrong answer[C1]
Finished, time used: 765 sec
Remove/Install battery now !
Old 02-08-2009, 13:24   #6 (permalink)
.::adnangsm::.'s Avatar
Member: 802214
Sonork: 100.1573572
Thanks Meter: 95
If you will see error at the same address it may be that phone hardware is damaged (f.e. damaged or bad soldered flash chip).
Old 02-08-2009, 13:28   #7 (permalink)
gul_hassan528's Avatar
Member: 420821
Sonork: 100.1603493
Thanks Meter: 731
hi to all
dear rehot flash ic and full flash ur fone
br
gsm afghan
Old 02-08-2009, 15:13   #8 (permalink)
Member: 238519
Sonork: 100.1589249
Thanks Meter: 20
Flash with GsmMulti.... 100% works..
Old 02-08-2009, 16:44   #9 (permalink)
Member: 802214
Sonork: 100.1573572
Thanks Meter: 95
u flash with FuriouS-Gold my be ur phone ok
Old 02-09-2009, 08:14   #10 (permalink)
Member: 421117
Thanks Meter: 2,519
thanks to adnan, gul and kamijeewan for posting.
i returned the phone to customer ,anywayz.
Lg kp199 dead by infinity box zubairok Infinity-Box 33 04-01-2011 13:37
Lg-kg290 flash not support infinity box ..::[email protected]::.. Infinity-Box 2 09-08-2009 22:42
X760 dead by other box repaired with Infinity!!! jepetu Infinity-Box 1 08-05-2009 23:21
Rm-17 n95 dead rivive by infinity box ayhen42 Infinity-Box 1 09-20-2008 13:16
C2200 Dead By Infinity Box alamgarh Infinity-Box 4 02-22-2008 10:02
Page generated in 0.34969 seconds with 8 queries
