10-24-2007, 08:06 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | KG290 Unlock Ok Enhanced Method Only COM14 [VCP0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: unlock unlock method: enhanced Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 35745601122xxxx file saved: backup_eeprom_35745601122xxxx_LG KG290_20071023-231231.B1E.bin .............. Check flash Done Check space... current eeprom imei: 35745601122xxxx .................................................. .............. finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done error: wrong answer[C1] Finished, time used: 54 sec Remove/Install battery now ! ---------------------------------------------------------------------- Thankx Infinity Team..Note Always Try unlocking on Both Provided Methods |
N N95 8gb unlock ok . time 39s only. think .MT BOX. | aleem26 | Nokia Base Band 5 ( BB-5 ) | 0 | 04-06-2009 10:32 |
kg290 unlock ok 10000% | farhaneng | Infinity-Box | 6 | 01-07-2009 08:41 |
w490 unlocked ok but now only flash mode | japunlock | Smart-Clip | 6 | 02-14-2008 08:45 |
LG KG290 unlocked in infinity-box using standard method | amps_jas | Infinity-Box | 1 | 01-08-2008 13:56 |
Lg Kg290 Unlock Ok | PARMATMA | Multi-box LITE | 0 | 10-31-2007 07:52 |
