01-19-2009, 14:05 | #1 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 437 | KG800 UNLOCK - Always error COM13 [VCP0] selected module v1.36 Device: LG-KG800 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... error: boot failed: Release Power button now ! error: unexpected answer during boot procedure Boot Fail Finished, time used: 6 sec Remove/Install battery now ! |
01-19-2009, 15:07 | #2 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: india
Member: 618404 Status: Offline Thanks Meter: 311 | Quote:
reset full factory default. & then use sim wbr. rajesh ch. | |
The Following User Says Thank You to rajesh_ch For This Useful Post: |
01-19-2009, 19:53 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, Here is list of supported models: www.infinity-box.com If you want to see your model supported, please, try to select other models one by one and try to read flash. When you will be able to connect phone please, post here an information about connection process and we will try to check what is wrong with software. |
01-20-2009, 03:57 | #5 (permalink) | |
Member: 64823 Status: Offline Thanks Meter: 437 | Quote:
Help !!! N85 can't unlock, always error booting rap- SOLVED! :-) | rikolaj | Cyclonebox | 9 | 07-23-2009 09:12 |
CU720 At&T can`t unlock always error supported version | juanbanco | Easy-Unlocker | 3 | 12-03-2008 00:59 |
SAGEM unlock always error, helpppp | sammy75 | KULANKENDI Server | 8 | 01-10-2008 04:14 |
Kg800 while unlocking always Error??? | ~mr_Ten$ion~ | FuriousGold | 14 | 09-24-2006 08:31 |
Myx1-2 not unlocking always error | david69 | Redbox | 6 | 11-09-2005 22:25 |
