Old 02-07-2019, 17:01   #1 (permalink)
lionfinger2007's Avatar
Member: 576282
Thanks Meter: 145
Kgtel K2130 Phone Lock Code?
I wanted to read or reset this Kgtel K2130 phone code and is not working, please how will I do it?
Logs below;
Card found : S/N : B25B7C49 , v0137
Chinese Miracle II [RDA module] v 1.05
Operation : Check Device / Info
======= Settings
Settings : Read AllInfo is On
Settings : Full Boot disabled by default
Waiting phone ...
Connect battery, press and hold '0' button
Connect USB cable and keep hold button, until phone will be detected
Phone not found
======= Settings
Waiting phone ...
Init : CCCCCCCC
Settings registers ...
1st boot Ok
==== CPU
CPU_ID : 0809 , rev : 0007
CPU_CN :
==== FLASH
FL_VEN : 0000 , rev : 0000
FL_CNM :
FL_CAP : 00000000
Initial : 81C0024C
Boot Done!
Elapsed: 00:00:25
Done
Reconnect Power/Cable!
Operation : Read User Code
Waiting phone ...
Init : 169FFD0C
1st boot Ok
==== CPU
CPU_CN :
==== FLASH
FL_CNM :
FL_CAP : 00000000
Initial : 81C0024C
==== Booting
Sending RamRun Loader ...
Set : 0809 , 00000000
Boot File Not Found! CPU not Supported , or BootFiles are missng. Contact to Support!
Old 02-07-2019, 18:19   #2 (permalink)
Member: 1677653
Thanks Meter: 2,769
Try format option instead
Old 02-07-2019, 18:29   #3 (permalink)
babarmughal's Avatar
Member: 2609063
Thanks Meter: 103
use SCR module ... whats the result ?
Old 10-07-2019, 14:33   #4 (permalink)
Member: 2706332
Thanks Meter: 19
Done By Miracle Box (RDA Tab)
CM2 doesn't seem to be working
Old 11-21-2019, 14:43   #5 (permalink)
Member: 1985680
I have this same issue but my miracle software is complaining format not supported
Please help
Old 11-21-2019, 16:12   #6 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Please help
Answer already given :
http://forum.gsmhosting.com/vbb/f296...tures-2708677/
Old 04-24-2020, 17:51   #7 (permalink)
Member: 2939236
Sonork: NULL
i have the same problem with miracle box
Old 04-25-2020, 12:02   #8 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
This is Infinity-Box section.
If you have any problem with software post log with problem details.
Br.
Infinity-Box Team.
Page generated in 0.20028 seconds with 9 queries
