Old 05-05-2018, 03:22   #1 (permalink)
Member: 2713959
Thanks Meter: 5
Vivo v7 imei repair
After reset frp, imei number invalid
Need solution
Old 05-05-2018, 04:36   #2 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
Need solution
Exe not touch any imei related partition while remove frp..
and always post logs/screenshot
Old 05-05-2018, 05:19   #3 (permalink)
Member: 2713959
Thanks Meter: 5
I don't have logs now
Please help me to solve, i closed the application
Old 05-05-2018, 05:27   #4 (permalink)
Member: 2211790
Thanks Meter: 5,118
you can find logs C:\InfinityBox\CM2QLM operation.txt
and about your imei issue you can try to repair with cm2qlm if baseband ok
if not retrieve baseband first
The Following 2 Users Say Thank You to kamal_singla For This Useful Post:
Old 05-05-2018, 06:49   #5 (permalink)
Member: 2713959
Thanks Meter: 5
I tried to repair
First enabled diage port, then not detecting in cm2
Old 05-05-2018, 06:52   #6 (permalink)
Member: 2211790
Thanks Meter: 5,118
as i know vivo qlm need different port(not diagnostic port) for repair imei
Maybe not supported atm or wait for community answer
Old 05-05-2018, 06:55   #7 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Need make sure about port has been appear.
Need make sure about drivers installed.
Need make sure about device BaseBand in alive state.
Page generated in 0.15507 seconds with 8 queries
