KONKA 635 digicel unlocked???????????? Can infnitybox unlocked this model coz near to this model is konka 636 supported but different pinout.. TIA. infinity team.. |
i mean KONKA C635.. Pls. infinity team.. |
yes of course....i unlocked almost 50 units... |
correction... is it c625, or c635? |
What selection model did u use coz when i select c636, it has error with read codes.. Coz no c635 there. Logs. COM8 selected Action: read codes unlock method: read codes Model: Konka-C636 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6223:8A04]... CPU: MT6223 chip: 0011:133D:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2005.07.11 Version: 1.0 Version: KAB635C_JMA_En_Fr_Sp_1.03.B22 Version: KONKA23_07A_HW 65 byte(s) read imei: FFFFFFFFFFFFFF connection Ok 69 byte(s) read reading data#2... reading data#3... reading data#4... reading data#5... error: operation failed ! Finished, time used: 11 sec Remove/Install battery now ! TIa. Pls. infnity team... reply asap.. @carlluvjo It is konka c635 not c625.. imei 3xxxxxxxxxxxxx. |
correction..its c625..not c635...try to unlock in chinese other option |
@cetech use "ChineseMiracle" software and read full flash from this phone. Send full flash backup to [email protected] so we will be able to check it. What is C635 pinout ? Also, here is an information for you what to do if you have new model: http:///vbb/showthread.php?t=546293 |
@cetech what's up did you unlocked konka c635? |
Hello, use \"ChineseMiracle\" software and read full flash from this phone. Send full flash backup to [email protected] so we will be able to check it. What is C635 pinout ? |
where is the thread starter?can you show us the picture? by the way in addition, last day i unlocked 15 c623 units..hehehe..thanks infinity!!! |
Hello, We are interested in flash backup to [email protected] so we will be able to check it and make update for this phone ASAP. |
