07-31-2008, 08:42 | #6 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | yes, but the pinout shown on Shell is for the 2x5 connector, I have a C625 with MiniUSB Connector, like moto phones, I neeed the pinout for this one, it has some testpoints inside but I am not sure where to put rx, tx, perhaps you know. |
08-02-2008, 02:24 | #8 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | I double checked, it is mminiUSB connector, it even can use the miniUSB cable to charge the phone. it has soem tespointns inside can you tell me if I can use these TP to connenct the cable ? |
08-02-2008, 04:29 | #9 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | also, I dont have this phone connector, at least I dont seem to see any on the package shipped with infinity, so, is there any correspondence between the TP on PCB and the connector ? so I can put the wires directly there? |
08-02-2008, 09:51 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I strongly suggest you to check your phone connector again and you will see that Konka-C625 has 2x5 (two rows by 5 pins) connector that very similar to ordinary mini-usb but is NOT the same ! Please, do NOT ignore my advice ! I am really surpriced that you do not want to check phone connector carefully. PCB test points: 2 4 1 3 5 3: Phone Rx (RJ45 pin-2) 2: Phone Tx (RJ45 pin-3) but to be honest I can not understand what is the usage of these test points if you can not find other 5 pins at phone connector. Are you sure that you will be able to build cable via PCB test-points ? |
08-03-2008, 01:23 | #11 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Hi there man I know I sound like a stupid or newbie, but am not. I am a newbie at infinity because I just baught the box, am very happy and satisfied with it, before having this, I used to use Usb to serrial FTDI based cables and I had no cionnectors, I have managed to solder wires on most connectors to get the phones connected. I dont have this phone connector, probebly you are right with the connector I cant verify right now because I returned the phone to customer, I prefer the to solder the wires into the PCB juyst as I do with alcatel c701, c717, etc, it is very simple. I dont know where to find this 2x5 connector on the infinity package, is there anay cable in there with this connector? Anyways, I will use the PCB testpoints next time. yurais |
08-03-2008, 01:27 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you need different connector types and if you often have phones with different rare connectors I suggest you to think about Infinity-Box PinFinder: http://www.infinity-box.biz/index.ph...infinder&lg=en As about C625: I have this phone on hands and for sure connector is 2x5 even if it looks like ordinary mini-usb. |
konka c625 user/phone lock | derk | Infinity-Box | 8 | 06-30-2009 12:31 |
Konka c625 pinouts | Nasmi | Chinese Models & Cloned Phones | 0 | 11-08-2008 06:13 |
@INFINITY TEAM i Have KONKA c625 | JammerTwo | Infinity-Box | 6 | 07-30-2008 13:06 |
konka C625 and C636 | men | Various | 6 | 06-17-2008 11:35 |
18 Mar 2008: Konka-C625 model supported | InfinitySupport | Infinity-Box | 26 | 03-20-2008 19:18 |
