09-20-2008, 08:34 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Afghanistan Kabul
Member: 295886 Status: Offline Sonork: 100.1583369 Thanks Meter: 1,472 | Konka-C625 unlocked succesfully COM85 [VCP0] selected Device: Konka-C625 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 89887200010001:89887200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb imei: 3570390130884520 Check hardware done Read data... reading Konka-C625_3570390130884520_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Konka-C625_3570390130884520_eeprom_calibration-1_20080917-161640.80E.bin Read data done Check data... simlock structure #1 pass-1... Check data done Writing... flash: 89887200010001:89887200000000 Write: eeprom Writing done Finished, time used: 88 sec Remove/Install battery now ! |
The Following User Says Thank You to Maiwand khan For This Useful Post: |
09-20-2008, 08:36 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
02-28-2009, 20:22 | #4 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
please help me how to flash and unlocking konka c625 | noey | Infinity-Box | 1 | 10-21-2009 22:23 |
..::Konka-C625 Unlocked Succesfully With Infinity Box::.. | Sahil2007 | Infinity-Box | 0 | 03-01-2009 19:25 |
help to unlock zte f156 & coral 300 & konka c625 | chris2007 | FuriousGold | 1 | 08-07-2008 03:41 |
konka C625 and C636 | men | Various | 6 | 06-17-2008 11:35 |
konka c625 unlock fail.. | carlluvjo | Infinity-Box | 8 | 03-27-2008 03:50 |
