Old 09-18-2008, 10:02   #1 (permalink)
Shubhanshu~'s Avatar
Member: 65074
Sonork: 100.1611263
Thanks Meter: 214
can anybody share file for This set...
Today i got on Chinese Phone marked on back label as Rocky-2008
According to User the Set got dead during Photo capture.
When Checked with Infinity, The Set Seems to be with Blank Flash.
Here are the pinouts
Initializing...
done
Cable: 2x5 (L10B)
Power On !
software version: 1.14
cable type: 2x5 (L10B)
platform: MT: MT6205, MT6217-MT6228, MT6230
searching adapter at COM13...
adapter found, version: 2000
pins: 10, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
CPU: MT6225
result: Rx:3 Tx:8
time required: 14 sec
Power On !
saved: Rocky_2008
Here Goes the operations log
COM13 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:6E03:0005
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:FFFFFF00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support (mt62xx[at]mail.com) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
operation terminated by user
error: critical error#1 during ffs size detection
error: can't detect eeprom/ffs address/size
error: chip layout not detected
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Finished, time used: 84 sec
Remove/Install battery now !
Please Check attchments for cfi_xxx.bin file.
Do anybody have flash file for this set???
Thanks
File Type: rar cfi_00EC_257E_2508_2501.rar (185 Bytes, 8 views)
Old 09-18-2008, 23:27   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
yes, this phone has empty flash.
now it is very hard to advice flash file.
better if you post phone picture, maybe someone will recognise it
Can anybody reveal exports from this file??? [Shadab_M] GSM Programming & Reverse Engineering 0 11-15-2009 16:41
can anybody share how can flash g700 set on setools debmobile SETool2 2 01-05-2009 06:19
can anybody share what parts this plese debmobile Samsung Hardware Repair 3 12-11-2008 07:50
Can anybody share this file plese. debmobile Infinity-Box 6 11-23-2008 21:07
can anybody share C35 flasher with me? igor_m x1x to x45/x50 0 09-07-2000 08:58
Page generated in 0.18995 seconds with 11 queries
